what's the advantage/disadvantage or using either one?
i used to use dvdfab + anydvd + nero recode to rip/shrink/burn dvds. but i came accross this one dvd that nero recode couldn't shrink properly. so i tried dvdshrink and used nero to burn it.
also, would it be better to uses anydvd+dvd decrypter or anydvd+dvdfab? i've seen movies that dvdfab couldn't rip, and dvd decrypter had no problems with. i've also seen some that dvd decrypter had problems with but dvdfab had none.
I use ripit4me, which beats all protection, and loads the ripped disc into Shrink ready to go, if you want. It uses DVD Decrypter to rip, and creates a PSL file so Decrypter can beat the structure protection if necessary. Because it does this on the fly, you don't have to keep downloading new versions like you do for DVD Fab Decrypter or AnyDVD.
I usually use DVD Rebuilder Pro to change or reduce the size for single disc burning.
I like AnyDVD because it has other useful features, like stopping audio CD protection from installing, however I would not install DVD Fab Decrypter again. I found it clunky, brutish, and not worth my time.Read my blog here.
I've used DVD Shrink for several years to backup my DVDs. If shrink can't decrypt, then I use DVD Fab Decrypter first. I never really needed anything else.
I now use ImgBurn to burn the Shrink conversions. I prefer freeware solutions whenever available. I still use DVD Decrypter, but not so much for burning.
DVD Decrypter rips where DVDFab can't
By audax in forum DVD RippingReplies: 2Last Post: 3rd Jan 2010, 19:27 -
DVDFab Decrypter
By HacktheHacker in forum DVD RippingReplies: 11Last Post: 25th Feb 2008, 23:10 -
dvdfab platinum and dvd hd decrypter
By marioval in forum DVD RippingReplies: 4Last Post: 8th Jan 2008, 14:40 -
DVDFab HD Decrypter???
By bltprf in forum Newbie / General discussionsReplies: 11Last Post: 9th Jul 2007, 00:09 -
anydvd + dvd decrypter or dvdfab?
By jamescardenas07 in forum DVD RippingReplies: 27Last Post: 15th May 2007, 19:29
