I am getting close to authoring a DVD, and from all the tools i've seen so far, the tempates that come with them are pretty crappy looking.
Is there a good resource with some DVD menus? I am not looking to donwload templates, just want to see some good menus for inspiration.
Results 1 to 16 of 16
Go to the Forum Search tool and type in Menu Samples.
You have to press Enter, then select a thread and view. -
A "template" will be specific to a particular authoring program.
I generally use a text menu on a static image. You should make some tests to see what looks best on your player/TV; it's not the same as on a PC screen. For instance, I find Verdana 20 points a nice legible font when I have five or six titles. If I need to show more text, Trebuchet 18 points is more compact and still clear. Occasionally I use a more decorative font for atmosphere. For backgrounds, for most subjects you can find many desktop wallpaper files on fan or promotional sites, which perhaps require only a little trimming to be suitable.
I don't bother with previews or moving backgrounds, seems pointless and irritating after the first time. But some enjoy making these. -
i deserve that. I've looked thought this forum, and found some good samples.Originally Posted by Nelson37
Still anyone of a website?
AlanHK, i know templates are program specific. Since i am working on a family video, that will probably be viewed by quite a few of my family members, i will spend time on previews and such, but not too much. -
If you search for DVD menu templates, you will find a number of outfits who sell pre-built templates - usually photoshop type layered stills or short video clips. However for the most part they are as cheesy as anything pre-packaged with your authoring tool. A quick google found these
http://www.digitalvideoteam.co.uk/
http://www.dvd-makers.com/products/department24.cfm
http://www.dvd-replica.com/photoshop/flowertheme1-1.php
None of these would I ever consider paying for or even using.
I prefer to create original menus based on the needs of the client or type of content. I find stock photo sites a great source of base materials. There is a good starter list here https://forum.videohelp.com/viewtopic.php?t=310099Read my blog here.
To me, the best menus are the ones with intuitive and quick navigation. No matter how fancy it looks, if it's hard to navigate then I will hate it.
guns1inger, thanks, i see what you mean about those sites. Nothing exactly inspirational.
jsmithepa, i know exactly what you mean, and i totally agree. -
you'd better use the search to find what interests you.
SPAM
<image removed>
You are in breach of the forum rules and are being banned for spamming.
/ Moderator mats.hogberg -
I've been using DVD Lab Pro 2. I just got DVD Architect 4 and it seems pretty limited and not very friendly.Originally Posted by vegetano1
Anyone know any good articles on using this? I haven't done much with it yet since the interface seems to be clunky.
LS -
what should i avoid when selecting/formatting fonts? for example, i selected a font for text and when i viewed it on my tv, portions of some of the letters were missing. in another instance, i used a color on a black background that made it look like the letters were vibrating.Originally Posted by AlanHK
any tips would help.
thanks! -
It needs to be fairly plain, as it loses some detail and can be hard to read on screen. Make them at least 12-14 point minimum, and try to stick with bolder fonts that are sans-serif.
...look like the letters were vibrating.
Can be avoided if the image is blurred before the authoring (encoding) step. Depends on your authoring program if this can be done automatically.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Commercial releases do not blur their menus. They go the route I've suggested, using safe colors combination and legible fonts. Blurring is not suggested (often called anti-aliasing in authoring software).Originally Posted by boraxWant my help? Ask here! (not via PM!)
ps3 cooling fan ideas - would a laptop chill pad do any good?
By yoda313 in forum Off topicReplies: 4Last Post: 15th Jun 2011, 18:58 -
Any ideas on choosing a good NAS device to store movies and such on?
By ryangarfield in forum ComputerReplies: 0Last Post: 20th Nov 2009, 09:57 -
What's a good DirectShow programming resource?
By JCipriani in forum ProgrammingReplies: 1Last Post: 22nd Jun 2008, 19:33 -
Coming Up with Good Video Ideas?
By austinm in forum Newbie / General discussionsReplies: 22Last Post: 4th Apr 2008, 17:46 -
Any good ideas for an engagement DVD?
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 22:03
