Hello all just picked up my first DVD-R burner so i can creat some custom DVDs. Only problem is ive been looking for a program to convert my .wav pcm audio to mpeg-1 layer 2 audio @48khz. Seeing as the standard of audio for DVD compliancy is 48khz, my old proccess of converting to mpeg-1 layer 2 @44khz using cdex will not work as the program will not encode to 48khzWhat im looking for is a simple program to convert the audio only (so i can muliplex the audio) from .wav format to the mpeg-1 layer 2 @48khz.
If anybody can help it would be greatly apreciated
sc0rp
If your wav-source is 48Khz then you can just use toolame.exe (see the tools section) to convert it to mp2 at 48Khz.
If your wav-source is not 48Khz then you could first upsample it with Shibatch Sampling Rate Converter (SSRC). After this, use Toolame. SSRC is here: http://freshmeat.net/projects/ssrc/
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
No 48kHz options in MPEG-Layer 3 in VirtualDub and Mod
By ashwin.terminator in forum AudioReplies: 24Last Post: 6th Apr 2009, 14:07 -
Converting .FLV audio to .WAV
By socool135 in forum AudioReplies: 1Last Post: 20th Feb 2008, 19:24 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51
