Need some recommendations for DVD±RW Burner.. LG, LiteOn, NEC, Pioneer.. Is there some good, stable model?
Results 1 to 9 of 9
I chose Pioneer 111D which I cross flashed to 111L after reading all reviews and many user reported problems at cdfreaks. The Pioneer seemed tp have fewer user problems as well as being best over all in cdfreaks reviews. The only knock against the Pioneer IMO is that it's not a good scanner, but that's much less important to me than quality burns which is main reason most get a burner anyway.
Have an NEC ND-3550A and it's awesome. If I flash with the Liggy's Bitsetting Firmware 1.06, it'll bitset single-layer +Rs as well as the DLs it already does.
I have a Pioneer 111D and the new Samsung 18X drive. This also makes the 4th or 5th Pioneer I have had over the Years. I like the Pioneer's. Just my 2 cents..
I have a Pioneer 111D and a Lite-ON SHW-160P6S.
I use the Pioneer to burn DVD-R and DVD+R DL. The burner automatically bitsets the double layer discs to DVD-ROM.
I use the Lite-ON to rip the movies (ripping speeds are higher than on the Pioneer) and to have a drive that works with KProbe scanner. Since the Pioneer doesn't have DVD+R bitsetting to DVD-ROM, I'd use the Lite-On to burn those. -
BENQ 1650/1655 is also another good drive to consider but it's getting scarce to find so the Pioneer 111D would be good choice too. -
I find LG drives to be extremely tolerant of many brands of blank media.
If you check the DVD media lists you will find that very few of the complaints of "bad media" are from LG owners. -
I have had no problems with my Benq's. You don't have to void the warrantee to bitset, as the Benq can be set to bitset. I have had no problems with media, although, I stay with store purchased blanks from Japan. I am now using Sony DVD+Rs from Japan with no problems.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
Recommendations for Blu-Ray Burner with LTH media support
By TBoneit in forum DVD & Blu-ray WritersReplies: 12Last Post: 19th Oct 2010, 16:43 -
External Blu-Ray Burner Recommendations
By derekwc in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Aug 2010, 22:35 -
Recommendations for DVD Burner
By dqtus in forum DVD & Blu-ray WritersReplies: 9Last Post: 11th May 2009, 11:59 -
I Need New Burner Recommendations Badly
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Sep 2008, 16:05 -
DVD Burner Recommendations
By ctdvd in forum DVD & Blu-ray WritersReplies: 4Last Post: 31st Aug 2007, 19:37
