    Oct 2003
    ok all help would be grateful--
    dled some bodybuilding rm files and want to watch em on my dvd player
    ive tried all the software possible to convert em to dvd vob and i keep getting a couple of % done and it crashes
    i get buffer underflow on some proggys
    and my cpu is at 99 to 100% when i start the convert
    ive 512 mb of ram and a 2800 processor
    ive converted other formats like svcd and avi alright
    i think its because im using to much cpu and the buffer over flow makes it crash ,i may be wrong
    plz assist
  2. Banned
    Mar 2006
    Denmark
    Try Winavi Video Converter. it should be able to do what you want
    Nov 2002
    smetone: you didn't check the guides, did you?
    Nov 2004
    Las Vegas
    smetone,
    Have you tried using Super for the conversion? I've used it a few times to convert rm files, and it worked very well. It's also freeware, so it doesn't cost you anything to give it a try.
    Oct 2003
    yes ive tried super and most others still same
    and yes i have looked at the guides ,is there something ive missed,i know the problems with my cpu overload
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Have you tried looking at the error message SUPER gave you? It usually attempts to suggest some workarounds or solutions.
