  1. Member scottb721's Avatar
    Oct 2002
    Australia
    Sorry, been out of the loop for a while.
    Trying to use shrink to back up kids movie High School Musical.
    Shrink thinks there are 2 copies of the movie on the DVD.
    The 2nd copy is just the main movie with some subs overlayed but shrink treats it as a whole movie and this makes it set a high compression factor.
    What's the solution ?
    thanks
    Apr 2004
    Miskatonic U
    Choose only one. If the disc has branching using playlists, Shrink sees these as two seperate movies, and processes them accordingly.
    In the case of HSM, one is the Karaoke version, hence the subtitles (yes, I have a daughter). If you want to keep both versions, menus etc intact, try using DVD Rebuilder to compress instead.
    Read my blog here.
