OK, I've been doing some looking around, and I can't seem to find it. How to rip a DVD to a single VOB on OS X? I'd then use the VOB with ffmpegX to make iPod video (640 pixels wide).
Thanks, but that just gives the main feature, in a bunch of separate vobs. Is there a way of creating one massive vob to encode with ffmpegX, as a single movie file?
IIRC, the newer versions of MTR have this feature under Title-Chapter Extraction.
Oh, I see. You must mean the 3.0 beta of MacTheRipper. Unfortunately, I only have 2.66.
However, I'm not sure if I'm using ffmpegX right, so it may be moot anyway. I tried using ffmpegX to transcode (with the 640w setting for the iPod) another .vob file I had.
It didn't work. I got an empty file, in one second. Anyone having similar troubles? -
It's an oldie but a goodie.Originally Posted by dr9553Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
Single .VOB file into working DVD?
By AHK in forum Authoring (DVD)Replies: 14Last Post: 5th Sep 2011, 12:38 -
how to link together 3 .VOB videofiles to create a single DVD
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2010, 06:27 -
dvd burning with a single vob file
By rtr720 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 04:22 -
n00b question about pulling out clips from a dvd. HELP!!!!!
By CaptainZissou in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2009, 02:03 -
DVDFab Platinum - rip into single Vob?
By nrishiraj in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2008, 18:33
