  1. its my understanding that .rat dvd is a dvd compression techinique
    is there Mac software to uncompress and compress this standard?
    cheers
    rotut
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
    USA
    It was never ported over to Mac, AFAIK. And there haven't been any new PC versions since Dec 2005, so the answer is probably no and never.
    A few have tried to run it on Virtual PC with a Mac but not much luck there, either.
    As a format, RAT kind of came, and went.
  3. Member CrayonEater's Avatar
    May 2006
    It's called FluxDVD now and is proprietary. The ratDVD format is still good for backups, archiving and transmission, but, as Redwudz said, it kind of ran its course as an open-source product.
  4. Thanks Cray and Red
    GreaT Logos!!!!
    BTW how did you get the cat to 'chomp'?
    means that Cray had to get the "G" to pour !!
    thanks
    MigliaMiniHD
    MPEG Streamclip
    G4dual 2GB
    AlchemyDVR card
