hi, can anyone help, im using belight and trying convert a ntsc (23.976) ac3 file thats 5.1 448kbps to a PAL (25.000) ac3 file with the same bitrate and 5.1 channels.
everytime i convert it, the ending file ends up the same filesize and same framerate, and yes if set the setting right in advanced settings.
wierd thing is, if i do the same thing ntsc 5.1 448kbps ac3 file to pal 2.0 448kbps ac3 file. It works fine and converts the frame rate.
any help would be sweet, thanks.
Since when does "sound" have framerate info? Sound only have sampling rate and channels (and bit resolution).
besweets framerates are just a representation to try ot make it similar to video. It has no basis in actual fact, just a front end device.
I would ask why you are converting. Most, if not all, players and TVs in the UK will accept NTSC material. Format conversion, especially by software, is almost always more trouble than it's worth, and always reduces the quality of the material. If you must convert, use the DGPulldown method, which avoids the need to alter the audio at all.Read my blog here.
The FilmMachine does it perfectly using besweet and gives you a nice corresponding AVS script with correct 4:3/16:9 sizing and borders to load into the encoder of your choice.
Also supports multiple similar AVI input and txt subs.
EDIT:
Heres a log of what it does.
BeSweet v1.5b29 by DSPguru.
Using azid.dll v1.9 (b922) by Midas (midas@egon.gyaloglo.hu).
Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using AC3enc.dll v1.20 (Feb 18 2004) by Fabrice Bellard (http://ffmpeg.org).
Logging start : 09/27/06 , 02:57:04.
BeSweet.dll -core( -input ac3input -output C:\PROGRA~1\THEFIL~1\Output\TFM_Encoded_Audio.ac3 -logfile C:\PROGRA~1\THEFIL~1\Output\TFM_Encoded_Audio.log ) -azid( -g max ) -ota( -fs 48000 -r 23976 25000 ) -ac3enc( -b 448 -6ch )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : ac3input
[00:00:00:000] | Output: C:\PROGRA~1\THEFIL~1\Output\TFM_Encoded_Audio.ac3
[00:00:00:000] | Floating-Point Process: No
[00:00:00:000] +-------- AZID -------
[00:00:00:000] | Total Gain: 0.000dB, Compression: None
[00:00:00:000] | LFE levels: To LR -INF, To LFE 0.0dB
[00:00:00:000] | Center mix level: BSI
[00:00:00:000] | Surround mix level: BSI
[00:00:00:000] | Dialog normalization: No
[00:00:00:000] | Rear channels filtering: No
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] +-------- FRC --------
[00:00:00:000] | Source Frame-Rate: 23976
[00:00:00:000] | Dest. Frame-Rate: 25000
[00:00:00:000] +------- AC3ENC ------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | AC3 bitrate : 448
[00:00:00:000] | Channels Mode : 5.1
[00:00:00:000] | Error Protection: Yes
Convert NTSC AC3 (29.970) To PAL
By DeathStalker77 in forum AudioReplies: 0Last Post: 26th Apr 2010, 22:09 -
PAL AC3 to NTSC AC3
By USiT2009 in forum AudioReplies: 6Last Post: 6th Sep 2009, 17:55 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
Belight settings for correct wave/ac3 volume conversion?
By spiritgumm in forum AudioReplies: 0Last Post: 29th Feb 2008, 13:19
