Results 1 to 9 of 9
  1. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Hello again :P
    My question now is:
    Wich program shoud I use to create some simple menus (with an image of my choice) and create also the chapters?
    Tmpgenc dvd author!
    <--- Tools and Author (DVD)
  3. Member PTsniper's Avatar
    Aug 2006
    Portugal
    wooh
    I see,
    sorry
    And thanks
  4. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    Easy: (TMPGENC) Pegasys DVD Author
    Hard(er but way more flexible and powerful): Mediachance's DVD Lab (and DVD Lab Pro)
    Similar to above, but cheaper (due to less features): DVD Lab Studio
    For *menu only creation* to feed into an authoring program (not tried but not likely to be any easier the DVDLab): Menu Studio (also by Mediachance)
    I prefer DVD Lab, for reasons stated above - it allows you to do far more in your DVD creation than DVDA will..Quite a bit pricier if I recall though (esp the Pro version). If all you want is a simple authoring program, then maybe DVDA is for you.. If you can find the older v1.6 release available to purchase, you may be able to go that route - it's cheaper than the newer v2.0(+), although not as 'feature packed' as it's successor.
    Other than those suggestions, check out the tools section and try out some demo's - you may find something you prefer over what I suggested.
    [edit] Damn - took to long to post Baldrick beat me to it :P .
  5. Member PTsniper's Avatar
    Aug 2006
    Portugal
    lol
    thanks a lot (to both), i gess I'll try Tmpgenc and DVD LAb.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    GUIForDVDAuthor is free and will do menu and chapters.
    Read my blog here.
  7. Member PTsniper's Avatar
    Aug 2006
    Portugal
    Isn't there any program that I can create a DVD without have to convert from Avi to Mpeg? I just want to add some Avi files to a DVD, but I want a menu.
    I really don't have time and pacient to convert the files.
    Thanks, once more.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I really don't have time and pacient (sic) to convert the files
    Buy a Divx certified player, live with the menu it gives you, and don't convert to mpeg2 at all. Otherwise, use CovertXtoDVD, live with the menu it gives you (you can change the background image), and be thankful.
    Read my blog here.
  9. Member PTsniper's Avatar
    Aug 2006
    Portugal
    lol
    I gess I'll try.
