Hello everyone.
I've a computer that has a Light Scribe maker or something like that.
My question is: how do I use light scribe in my DVD's, I know I need to buy the right DVD's otherwise it won't work, but do I need any program.
Does my recording program works?
Thank so much.
Results 1 to 20 of 20
We don't know WHAT RECORDING PROGRAM you have. Can't read mind, yet!Originally Posted by PTsniper
Go ahead, open it up, look for lightscribe, it won't bite, or blow up, promise!
If need more software, go to www.lightscribe.com. -
Yes, you need special LS discs, which are expensive, and software that will burn them. After burning a DVD you need to flip it over and stick it back in the drive to do the LS burn. The general opinion from what I've seen and read is that LS is expensive and produces poor quality - generally not much better than gray-scale.
Although anything is better than using sticky labels - sticky labels are a great way to wreck your DVDs - if you want good quality, look into inkjet printing and using inkjet-printable discs. If you burn a lot, the lower cost of the inkjet-printable discs might even offset the cost of the special printer and ink, compared with Lightscribe. -
I use the Casio CW50 on regular discs.
The TDK 8x +R are the best to print with, there are lines in these disk that makes
it very easy to align right.
I'm dessapointed, I tought the Light Sribe would do a better job (I tought it could make images).
Thanks -
This is a ******* revelation to me, that u can write lightscribe on regular discs. If this means I don't have to use my ugly-ass handwriting on my discs, I'm buying a lightscribe burner right now!Originally Posted by tonyp12
Can anyone confirm this? -
Sorry for so late sesponse.
Personaly I only tought that u could only use light scribe in proper DVD's. -
That's a label CD/DVD Thermal Printer - prints on a regular CD/DVD but has nothing to do with LightScribe.Originally Posted by tonyp12
/Mats -
wow, now I see waht light scribe is:
just see this example:
Thanks for all help. -
PTsniper you can donwload LightScribe API and a free labeler from here: http://www.lightscribe.com
I’m using LightScribe 16x Verbatim blanks. These disks are version 1.2. In my PC I installed in LighScribe API 1.4.105.1.
To burn the labels, I’m using Nero cover designer 2.3.1.3 (came with Nero 6.6.1.4). I also use SureThing CD labeler 4 SE (ver. 4.3.0192).
My burner is an LG GSA-4166B firmware 1.02.
I have burned several LightScribe disks and I have never obtained the results you show in the picture.
Real labels have low contrast and the label itself seems washed out even when using the best quality (30 minutes burn).
LightScribe is similar to the old Yamaha disk T@2 technology. -
wow, allright,
so what you're saying is that I will lose some of the quality when burning a Light Scriber DVD?
Thanks to all -
A friend of mine uses the Casio CW75 which is the "big" brother of the CW50 because it can be used without a computer (has a tiny keyboard on it and a lil LCD screen like on a calculator). The CW50 has no such "extras" and is just a printer that needs a computer hook-up.
He only prints simple TEXT only titles but it looks very professional. He uses the Taiyo Yuden 8x DVD-R discs from RIMA.COM which have a "shiny silver" blank top to them.
Wish I had one as I tend to put my DVDs in a case with artwork and not label or more often just use a CD/DVD safe sharpie marker (but my penmenship skills aren't so great).
- John "FulciLives" Coleman
P.S.
My friend's DVD discs look just like the sample provided by tonyp12 except my friend doesn't use such large bold text. I've been tempted to buy one myself but everytime I think about blowing $100 on a printer when I can just use a sharpie marker ... call me cheap but I'd rather use the $100 buying more blank discs LOL."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
You got it. LightScribe will never looks as sharp as the example in the picture. Not at least with current coating. This may improve in the future...Originally Posted by PTsniper
Sorry for so late response.
I just wanted to say thanks (to all of you)
Finnaly, now I know what light scribe is. LOL
I will but some Light scribe DVDs and try it. I hopw it works.
Thanks to all of you.
P.S. What program can I use to burn light scirbe DVD's, i think mine dowsn't have (my program is Sonic, or something like that).
Thanks once more. -
i use surething cd labeler. for best results use high contrast black and white images only with the output at the max quality.
free simple lightscribe cd label software -
http://www.lightscribe.com/support/index.aspx?id=662
list of other lightscribe label programs
http://www.lightscribe.com/products/index.aspx?id=105--
LED Camera Light
By budwzr in forum Off topicReplies: 6Last Post: 30th Dec 2011, 20:55 -
Scribe Transcription Software
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 27th Sep 2011, 17:02 -
Video from light projector?
By Compo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2011, 19:51 -
light scribe not working
By bnts1993 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2009, 14:41 -
Laser Etching DVDR That are NOT Light Scribe Discs.
By Scooter_NJ in forum Authoring (DVD)Replies: 4Last Post: 17th Nov 2008, 18:11
