VOD2MPG has worked perfectly for me until last night. I'm trying to convert a Friends with Money DVD Rip but it does nothing the first run and then say's it's complete the second time around after running for about 2 seconds!
Here's the log output;
The outputted mpg file is 0 bytes in size, the vobs total 5.53GB in size.Code:******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.3.0.0 Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 640 KB Executable size in bytes: 655360 Executable CreationTime: 14/03/2006 16:49:26 Executable LastWriteTime: 14/03/2006 16:49:26 Executable LastAccessTime: 26/09/2006 11:53:37 ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 38.2 GB FreeSpace: 28.8 GB DeviceID: D: FileSystem: NTFS Size: 76.6 GB FreeSpace: 7.04 GB DeviceID: F: FileSystem: NTFS Size: 149 GB FreeSpace: 108 GB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ********************** Input Folder ******************* 12:54:04: Volume in drive D is Music 12:54:04: Volume Serial Number is 78F5-5765 12:54:04: Directory of D:\Downloads\Temporary Download Folder\Working Folder 12:54:04: 26/09/2006 01:00 <DIR> . 12:54:04: 26/09/2006 01:00 <DIR> .. 12:54:04: 21/09/2006 21:41 77,824 VTS_02_0.BUP 12:54:04: 21/09/2006 21:41 77,824 VTS_02_0.IFO 12:54:04: 21/09/2006 21:32 45,772,800 VTS_02_0.VOB 12:54:04: 21/09/2006 21:35 1,072,713,728 VTS_02_1.VOB 12:54:04: 21/09/2006 21:37 1,073,739,776 VTS_02_2.VOB 12:54:04: 21/09/2006 21:40 1,073,739,776 VTS_02_3.VOB 12:54:04: 21/09/2006 21:41 530,352,128 VTS_02_4.VOB 12:54:04: 7 File(s) 3,796,473,856 bytes 12:54:04: 2 Dir(s) 7,569,534,976 bytes free 12:54:04: D:\Downloads\Temporary Download Folder\Working Folder> ******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.3.0.0 Executable: C:\Program Files\BadgerIT\VOB2MPG\VOB2MPG.exe Executable size: 640 KB Executable size in bytes: 655360 Executable CreationTime: 14/03/2006 16:49:26 Executable LastWriteTime: 14/03/2006 16:49:26 Executable LastAccessTime: 26/09/2006 11:54:16 ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 38.2 GB FreeSpace: 28.8 GB DeviceID: D: FileSystem: NTFS Size: 76.6 GB FreeSpace: 7.04 GB DeviceID: F: FileSystem: NTFS Size: 149 GB FreeSpace: 108 GB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ********************** Input Folder ******************* 12:54:38: Volume in drive D is Music 12:54:38: Volume Serial Number is 78F5-5765 12:54:38: Directory of D:\Downloads\Temporary Download Folder\Working Folder 12:54:38: 26/09/2006 01:00 <DIR> . 12:54:38: 26/09/2006 01:00 <DIR> .. 12:54:38: 21/09/2006 21:41 77,824 VTS_02_0.BUP 12:54:38: 21/09/2006 21:41 77,824 VTS_02_0.IFO 12:54:38: 21/09/2006 21:32 45,772,800 VTS_02_0.VOB 12:54:38: 21/09/2006 21:35 1,072,713,728 VTS_02_1.VOB 12:54:38: 21/09/2006 21:37 1,073,739,776 VTS_02_2.VOB 12:54:38: 21/09/2006 21:40 1,073,739,776 VTS_02_3.VOB 12:54:38: 21/09/2006 21:41 530,352,128 VTS_02_4.VOB 12:54:38: 7 File(s) 3,796,473,856 bytes 12:54:38: 2 Dir(s) 7,569,534,976 bytes free 12:54:38: D:\Downloads\Temporary Download Folder\Working Folder> ********************** AV Details ******************* file=D:\Downloads\Temporary Download Folder\Working Folder\VTS_02_1.VOB FormatName=mpeg Num_Frames=37553 DurationInSecs=1502 Duration=00:25:02.1 VideoCodec=mpeg2video Width=720 Height=576 Standard=PAL BitRate=5712 AudioStreamCount=5 Audio1StreamID=[0x80] Audio1SampleRate=0 Audio1Codec=ac3 Audio1BitRate=0 Audio1Channels=0 Audio2StreamID=[0x81] Audio2SampleRate=0 Audio2Codec=ac3 Audio2BitRate=0 Audio2Channels=0 Audio3StreamID=[0x82] Audio3SampleRate=0 Audio3Codec=ac3 Audio3BitRate=0 Audio3Channels=0 Audio4StreamID=[0x83] Audio4SampleRate=0 Audio4Codec=ac3 Audio4BitRate=0 Audio4Channels=0 Audio5StreamID=[0x84] Audio5SampleRate=0 Audio5Codec=ac3 Audio5BitRate=0 Audio5Channels=0 ************************ END ************************ 12:54:38: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard 12:54:38: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads 12:54:38: libavutil version: 49.0.0 12:54:38: libavcodec version: 51.4.0 12:54:38: libavformat version: 50.2.1 12:54:38: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special) 12:54:38: Input #0, mpeg, from 'multi:D:\Downloads\Temporary Download Folder\Working Folder\VTS_02_1.VOB*D:\Downloads\Temporary Download Folder\Working Folder\VTS_02_2.VOB*D:\Downloads\Temporary Download Folder\Working Folder\VTS_02_3.VOB*D:\Downloads\Temporary Download Folder\Working Folder\VTS_02_4.VOB*': 12:54:38: Duration: 00:00:27.5, start: 0.287267, bitrate: 1088692 kb/s 12:54:38: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 720x576, 9800 kb/s 12:54:38: Assuming PAL for target. 12:54:38: Could not find input stream matching output stream #0.1 ********************** Output Folder ******************* 12:54:38: Volume in drive F is Movies 12:54:38: Volume Serial Number is 2063-EDF2 12:54:38: Directory of F:\Friends with Money 12:54:38: 26/09/2006 12:54 <DIR> . 12:54:38: 26/09/2006 12:54 <DIR> .. 12:54:38: 26/09/2006 12:54 0 VTS_02.mpg 12:54:38: 1 File(s) 0 bytes 12:54:38: 2 Dir(s) 116,391,714,816 bytes free 12:54:38: F:\Friends with Money>
Any ideas what's up based on the log file?
Results 1 to 12 of 12
looks like it is having issues deducing the audio. What does gspot say about the various audio streams?
Ok. Can you email me a small sample with the attached? Say 5 or 10MB?
makesample.zipSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I was going to do that earlier, but the tool only appears to accept mpg files and obviously my mpg file is 0 bytes. Will it accept vobs?Originally Posted by ChrissyBoy
Do you have an FTP site I can upload it to?
Thanks for taking the time to look into this. -
Just choose "All files":
email will do at this end....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
OK.
I'm at work just now but am heading home in a bit so I will upload/send it to you then (probably in about an hour).
Cheers. -
no worries.
I've uploaded a 5MB sample to my FTP space. You can download it from http://mparter.pwp.blueyonder.co.uk/downloads/VTS_02_1-SAMPLE.zip
Not yet. Downloaded the sample and got the same as you... I will look into it as soon as my work load goes down!
Unable To Register BOTH SVCD2DVD & VOB2MPG Pro
By noyou in forum SVCD2DVD & VOB2MPGReplies: 19Last Post: 21st Sep 2014, 19:40 -
Can Vob2MPG convert audio streams?
By ThejafF23 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Dec 2011, 13:07 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
Problem to convert .VOB to .MPG with vob2mpg
By akakiami in forum Authoring (DVD)Replies: 14Last Post: 17th Mar 2009, 08:51 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 12:57
