I'm getting two files when using the new profile. A Video file with no audio and a Audio file that is Zero bytes. Why is this happening? I'm not changing any defaults within the Profile.
Results 1 to 9 of 9
Have you waited for the process to be "Finished" ?
It's not finished when it says "100%"
When the process reaches 100% it has finished encoding the videopart - it then exports and encodes the audio, and finally muxes the 2 files together - this all happens without the progressbar moving.
So you have to wait for it to say "Finished".
I'm getting the same exact problem. I'm using the iPod H.264 320w preset and I unchechecd decode with quicktime. Here's my output...all of it,
Any ideas?Code:FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Mac OSX universal build for ffmpegX configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264 libavutil version: 49.0.0 libavcodec version: 51.9.0 libavformat version: 50.4.0 built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250) Input #0, mpeg, from '/Users/ryan/Desktop/test.VOB': Duration: 00:50:52.1, start: 0.201478, bitrate: 15990 kb/s Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s Stream #0.1[0x20]: Subtitle: dvdsub Stream #0.2[0x21]: Subtitle: dvdsub Stream #0.3[0x22]: Subtitle: dvdsub Stream #0.4[0x23]: Subtitle: dvdsub Tue Oct 10 16:41:56 PDT 2006 m #0.5[0x24]: Subtitle: dvdsub Stream #0.6[0x25]: Subtitle: dvdsub Stream #0.7[0x26]: Subtitle: dvdsub Stream #0.8[0x27]: Subtitle: dvdsub Stream #0.9[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s Stream #0.10[0x89]: Audio: 0x0000 Stream #0.11[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream #0.12[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream #0.13[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream #0.14[0x85]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Output #0, yuv4mpegpipe, to 'pipe:': Stream #0.0, 29.97 fps(c): Video: rawvideo, yuv420p, 320x128, q=2-31, 200 kb/s Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding x264 [info]: using SAR=1000/1001 x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 mp4 [info]: initial delay 0 (scale 30000) video:0kB audio:0kB global headers:0kB muxing overhead inf% x264 [info]: slice I:2151 Avg QP:24.65 size: 4056 PSNR Mean Y:42.10 U:45.10 V:44.95 Avg:42.77 Global:41.40 x264 [info]: slice P:185036 Avg QP:26.69 size: 564 PSNR Mean Y:39.92 U:44.32 V:43.93 Avg:40.76 Global:39.26 x264 [info]: mb I I16..4: 30.3% 0.0% 69.7% x264 [info]: mb P I16..4: 3.4% 0.0% 2.5% P16..4: 47.9% 0.0% 0.0% 0.0% 0.0% skip:46.3% x264 [info]: final ratefactor: 26.29 x264 [info]: PSNR Mean Y:39.945 U:44.328 V:43.940 Avg:40.781 Global:39.282 kb/s:144.94 encoded 187187 frames, 111.30 fps, 145.03 kb/s FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Mac OSX universal build for ffmpegX configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264 libavutil version: 49.0.0 libavcodec version: 51.9.0 libavformat version: 50.4.0 built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/ryan/Desktop/test.VOB.ff.video.mp4': Duration: 01:44:05.8, start: 0.000000, bitrate: 146 kb/s Stream #0.0(und), 29.97 fps(r): Video: h264, yuv420p, 320x128 Input #1, mpeg, from '/Users/ryan/Desktop/test.VOB': Duration: 00:50:52.1, start: 0.201478, bitrate: 15990 kb/s Stream #1.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s Stream #1.1[0x20]: Subtitle: dvdsub Stream #1.2[0x21]: Subtitle: dvdsub Stream #1.3[0x22]: Subtitle: dvdsub Stream #1.4[0x23]: Subtitle: dvdsub Stream #1.5[0x24]: Subtitle: dvdsub Stream #1.6[0x25]: Subtitle: dvdsub Stream #1.7[0x26]: Subtitle: dvdsub Stream #1.8[0x27]: Subtitle: dvdsub Stream #1.9[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s Stream #1.10[0x89]: Audio: 0x0000 Stream #1.11[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream #1.12[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream #1.13[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Stream #1.14[0x85]: Audio: ac3, 48000 Hz, stereo, 192 kb/s Codec type mismatch for mapping #1.1 -> #0.0
-ryan
I checked all the other audio tracks by selecting them in the audio page one by one and then previewing them. Only track 0 gives the normal movie audio, but I get the above error when encoding with that one. Maybe I'll try encoding one of the other ones with commentary...
How can I convert MKV profile high@5.1 to MKV profile 4.1 ?
By utahmar in forum Video ConversionReplies: 53Last Post: 4th Nov 2012, 09:03 -
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04 -
How can I convert MKV profile 5.1 to MKV profile 4.1 ?
By Sanshero in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 04:40 -
By Sanshero in forum Video Streaming DownloadingReplies: 1Last Post: 26th Mar 2009, 13:32 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56
