is there any other program which can add audio back to a .mpg movie apart from VirtualDub and VirtualDubMod, as both wont do direct stream copy on the video side, also I have tried TmpENC but that wont take a .wav audio the movie I have is a .mpg and the audio is .wav I made the audio louder with goldwave, which I used VirtualDub to extract it
Click on "ES (Audio Only)" on the radio buttons on TMPGenc (ie cancel the wizard , the buttons are on the right hand side at the bottom) input the wav file in the selector space , set your bitrate and it will make the MP2 file from it (thats if you want it as MP2) ,
If you want to use an MP2 file , next use MPG Tools in the menu in TMPGenc to remux them . Other programs can do it , but you already have TMPGenc . -
Either the Simple Multiplex or Multiplex - yes . Most commonly called remuxing , at least in this forum it is .
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 08:59 -
Add a video stream to an existing mpg from MythTV
By nublaii in forum EditingReplies: 5Last Post: 22nd Sep 2010, 06:43 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 16:47 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 20:05 -
Add subtitles to an .MPG video
By Nilfennasion in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2007, 09:05
