Whenever I try to open a movie file with Quicktime Pro (latest version) that does not have the ".mov" extension the player will not open it and display the following error message:
"Error -2048: the file is not a movie file"
I tried uninstalling and reinstalling Quicktime without success. Any fix? Thanks.
Silly question, but have you tried adding the .mov extension to the files?Originally Posted by alegatorIf cameras add ten pounds, why would people want to eat them?
It's probably telling you that you are trying to play a non-supported format, try playing the file with Media Player or Media Player Classic. Check the Quicktime setup and look for file associations and see if the extension is supported.
Final Cut Pro, gives me GENERAL ERROR when exporting to Quicktime
By Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 14:26 -
Error 2048 Quicktime Problem (Home Movies)
By cliffm10 in forum Software PlayingReplies: 0Last Post: 19th Apr 2010, 11:06 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
AVI conversion error in Quicktime Pro
By oldsalt in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 17:16 -
Error on Uncompressed 10-bit 4:2:2 1920x1080 QUICKTIME to -> MPG
By peejeedee in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 19:04
