The workaround I've been using is to "clean" the files by running them thru DVDShrink without any further compression. That seems to always produce playable DVD's.
-The Mang
I have not posted this question in the DVD-RB forum. To answer your question guns1inger, I rip them either with DVDDecrypter or DVDFabDecrypter in file mode. I also encode them in file mode. I wonder if I do them in ISO if it will produce "compliant" discs for me. rkr1958 - Nice Dachshund. He looks like my dog Chillie
-The Mang -
ISO vs file mode is not your problem.
I would suggest using RipIt4Me to rip. It uses DVD Decrypter, but overcomes the ArCoSS structure protection is a safer and more suntle way than DVD Fab Decrypter, and you don't have to keep updating it.
How do you test for compliance ?
What makes you know that you have to run a particular disc through DVD Shrink ?
I have always found Shrink to be pretty fussy, and ready to turn it's nose up at any disc that isn't complete and compliant to begin with. I am surprised, if these discs are in the state you say they are, that Shrink will even load them.Read my blog here.
Discs that I burn straight off of the encode don't work on my players.
The only way they work is by running them thru DVDShrink and then they magically work.
I've been lucky in that DVDShrink has always accepted the encodes.-The Mang -
Originally Posted by louv68
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 09:10 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
