Hi,
I've downloaded a fully working trial version of Intervideos iVideotogo Platinum 5.
This converts a DVD to .MP4 format (for an iPod).
There is an option called 'CopyLater' which lets you 'batch up' a number of dvds to run at a certain time (overnight).
no mater what I try it just won't work, anyone else have problems/solution?
Intervideo aren't interested in supplying any help unless you purchase the product,
I don't want to buy the product unless I know it works.
The 'Convert DVD' option works fine, but only allows you to convert 1 dvd at a time (runs immediately).
thanks
Results 1 to 1 of 1
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
What do these option do and what to fill in these?
By tendra in forum Video ConversionReplies: 0Last Post: 30th Oct 2009, 21:17 -
Wich one is the best option?
By thenamelessthing in forum DVD & Blu-ray RecordersReplies: 18Last Post: 25th Aug 2008, 13:21 -
The Best Option???
By Dom_Sisko in forum Video ConversionReplies: 9Last Post: 15th Mar 2008, 00:56
