    Jan 2006
    xvid resolution change (800 to 720 or under): autogk and problem
    I have Philips 5960 player and it cannot read xvid with resolution 800 or higher. So, I need to change the resolution of the xvid files into 720 or under.
    After some research, I found that AutoGK is the right program to do it. Then, I succesfully changed the resolution on some files. But, on other files (they are all DD 5.1 ch AC3), they got error message "AVIoutputwav: file name, directory name or volume label syntax is incorrect). I found one thread that handled this issue. As advised, I demux audio file, convert it to wav/ac3 2ch 224kbps/mp3, and remax/save in virtualdubmod. I stil got same error message.
    I was wondering if AutoGK is still the easiest/best option to change the resolution (only, nothing else) of xvid files.
    Also, any solutions to clear the above error message in AutoGK?
    You can try avi recomp.
    But if you are using virtualdubmod you can do the reszing in it, video->filters resize and add a compression video->compression and choose xvid codec.
