  1. Is there a way to convert more than one file at once using TMPGE?
  2. open up 2 copies of TMPG.... ?
    Apr 2001
    Save project files, and batch encode them (It doesn't do 2 simultaneously, but will do one and then another right afterwards, you can let it go and it'll shut down automatically if you want)...
    To do 2 movies simultaneously (2 instances of TMPGEnc) would be piontless, since each would be competing with the other for CPU time, and would each go half as fast as it would normally.
