  1. Hey guys. This is my first post so be nice. I just received a DVD-RIP and I need to cut both files into 2 each (2 movies into 4 files) because they are both over 700 megs and I need to put some more stuff on the cds than just video. I HAVE TRIED EVERY SOFTWARE ON VCDHELP.COM for cutting. Nothing works. Most of the programs allow you to cut 10seconds, wow TMPEGNC or whatever doesn;t allow me to play my movie and yes I hav powerdvd/windvd installed. My first newbie question is, PLS PLS PLS SOMEONE TELL ME OF A PROGRAM THAT WILL ALOW ME TO CUT MY MPEG2 MOVIES INTO 2 . (Something thats free and easy to use) THX. I need the info asap, THX.
  2. UP- someone PLS answer this!
  3. u can demultiplex the file and multiplex again using tscv or BBMPEG and put the file split at 790 meg or whatever u want
    May 2001
    Hi Try DVtool
    CHEERS GARRY
  5. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    On 2002-01-12 09:04:02, garryward wrote:
    Hi Try DVtool
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    thx guys
