Here's a question:
Say a person has an HDTV DVR box that has, among other things, component video out. They also have a DVD recorder that accepts component video in. What would happen if they were to play back an HD program recorded on the DVR and attempt to record it onto a DVD+/-R(W) in the DVD recorder? Would the DVD recorder be able to receive/process the HD signal from the DVR?
Just curious.
Thanks,
Chris
No, it wouldn't work. Current DVD recorders on the market don't downsize an HDTV MPeg2_TS input.
But your DVR probably does. Connect S-Video to the input of the DVD recorder and record. Normally this would be letterbox 720x480i if recorded HQ. -
Thanks for the reply. So is the S-Video method the only way of doing this? If so, what is the point of manufacturing a DVD Recorder with component video in capability?
Thanks,
Chris -
What model are you looking at?Originally Posted by bigkromedogg
Analog component has potenital for higher quality than S-video but as far as I know they are all limited to 480i over YPbPr. 480p with true 16:9 would max the DVD format. I wish someone would make one of those.
HD recording is currently PC/Mac only at the consumer level and the cable company determines what can be recorded. -
The DVR is a Scientific Atlanta Explorer 8300 HD. The DVD recorder is a GoVideo RV4000.
Chris -
I have a SA8300 too and tried to pull some of my recordings off via the firewire port. Unfortunately Comcast in my area hasn't enabled the firewire ports. You might have luck doing that though depending on your provider.
The GoVideo RV4000 doesn't have component inputs. It doesn't even have S-Video in, only RF and composite NTSC (RCA).Originally Posted by bigkromedogg
http://www.govideo.com/Download/RV4000_sell.pdf
The only recorders capable of HD recording use D-VHS tape over IEEE-1394.
http://en.wikipedia.org/wiki/D-VHS
http://www.jvc-victor.co.jp/english/products/vcr/D-VHS-e.html
Recording HDTV & Satellite with PC?
By neworldman in forum DVB / IPTVReplies: 14Last Post: 4th Dec 2011, 18:16 -
Sudden resolution change when recording HDTV
By Strawson in forum EditingReplies: 9Last Post: 20th Aug 2010, 15:49 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 18:45 -
Recording cable HDTV via firewire
By hipser in forum DVB / IPTVReplies: 3Last Post: 18th Apr 2008, 18:58 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
