Hi,
I'm trying to use FFMPEGX to encde a vob file from a DVD. I am using the "iPod H.264 640w" preset and am changing the 'autosize' option in the 'video' tab to 4:3 (it default's to a widescreen ratio, which my source is not.)
When clicking encode, I get the finished 'ping' instantly and the log file has the following details:
Any help would be greatly appreciated.Code:Encoding started on Sun Sep 24 18:50:50 CDT 2006 movtoy4m Copyright 2002-2006 Johan Lindstr??m All rights reserved.. x264 [info]: using SAR=1000/1001 x264 [info]: using cpu capabilities Altivec mp4 [info]: initial delay 0 (scale 30000) ERROR: Could not open movie: /Volumes/Stuff/vobs/episode1.vob x264 [info]: final ratefactor: 53.13 FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Mac OSX universal build for ffmpegX configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264 libavutil version: 49.0.0 libavcodec version: 51.9.0 libavformat version: 50.4.0 built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666) [mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]Could not find codec parameters (Video: h264, 640x480) /Volumes/Stuff/vobs/episode1.vob.ff.video.mp4: could not find codec parameters
Thanks,
C.
The "iPod H.264 640w" preset defaults to Decode with QuickTime. But QuickTime can only decode the video in VOB files if you have the MPEG-2 Playback component installed.
So, either de-select Decode with QuickTime, in order to use a different decoder engine, or install the component.
How Can I convert avi(xvid) to ipod tv out (H.264)?
By felix in forum Video ConversionReplies: 8Last Post: 1st Sep 2008, 10:27 -
VIDEO_TS to iPod H.264 and subtitles
By veravera in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2008, 15:39 -
Ipod - h.264 or MPEG-4, which one is better?
By FallenAngelII in forum DVD RippingReplies: 1Last Post: 10th Jan 2008, 11:12 -
need a leopard compat program for creating ipod 640 files
By jayrives in forum MacReplies: 3Last Post: 17th Nov 2007, 01:50 -
converting to h.264 for ipod
By nagihcim1 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 08:27
