Hi. I've figured out how to get decrypted VIDEO_TS folders onto my hard drive using DVD Decrypter and other tools, and I know how to use TMPGEnc DVD Author to extract MPEG-2 files from them. Unfortunately, TMPG DVD Author only lets you convert one DVD clip to MPG at a time.
Is there any way I can select *all* the clips from a ripped DVD all at once and extract them to MPEG-2s all together? Are there any freewares that do this?
Thanks in advance for any guidance anyone can give me.
Take a look at VOB2MPG. It will extract the entire DVD video to one huge MPEG-2 file. You can also use DVD Decrypter if you set the 'File splitting' to 'None'. You will end up with one huge VOB of the DVD. Then you could use TDA to convert the VOB to MPEG-2.
Thanks, but wouldn't that just result in one large MPEG that I'd have to split again later? It was probably unclear how I wrote it, but what I want to do is take a DVD with, say, six cartoons on it and extract the six individual MPEG-2 files all at once.
Join multiple series of mpg files?
By Chasden in forum Newbie / General discussionsReplies: 17Last Post: 18th Sep 2014, 05:43 -
How to play multiple VOBs and a subtitle file
By kenj in forum Software PlayingReplies: 3Last Post: 22nd Jun 2010, 17:42 -
Joining multiple VOBs to make one AVI?
By RedCorvus in forum EditingReplies: 4Last Post: 6th Aug 2009, 09:57 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 11:25 -
Multiple DVDs/VOBs...
By takearushfan in forum Authoring (DVD)Replies: 6Last Post: 26th Aug 2007, 05:39
