Hey Gang;
Not sure this was covered before ..
Did search on it and no relevant info came up ..
Anywho, my Sony DW-D22A won't recognize Memorex dvd+r dl 2.4x disk ..
It's rated at 8.5GB but sez not enpugh space for a 7.4 GB dvd9 iso files ..
The Firmware is at BYS1 so I tried to update it to BYS3 but it would'nt take it for some reason ..
Used ltnFW.exe for that ..
If anyone came across similar problems and solved it, would appreciate learning the solution ..
BTW, have no problems burning dvd-5 files ..
Cheers !!
Z
you could also check out the sony/liteon forum at cdfreaks.com for more information on your drive.
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 14:52 -
my pc wont recognize my sony handicam dcr-hc21
By J.Frost in forum Capturing and VCRReplies: 3Last Post: 20th Dec 2009, 23:27 -
dvd fab wont recognize target burner drive
By lauraji in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2009, 00:34 -
convertx wont recognize avi
By brdhsby5 in forum Video ConversionReplies: 4Last Post: 20th Aug 2008, 17:01 -
Does not recognize disk
By GrizzlyJones in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 09:50
