  1. VDB gives me "cannot detect file type"....
    DGindex first tells me my video is 1088 and might have 8 pixels of garbage.
    After that it says:
    Warning! Opening GOP is not closed.
    The First Few Frames may not be decoded correctly
    Then it loads it, problem is, the resolution is 1280x1088 (or 1280x1080 if I said remove the 8 extra pixels)...
    MeGui also produced a 1280 file...
    How do I fix this?
  2. Guest34343
    Guest
    What's the problem? Just resize it as needed.
  3. Member stars's Avatar
    Apr 2006
    In the Lighthouse
    Hi I would use projectx for editing a .ts file and demuxing...
    Projectx usally generates a big error/warning list but the out put are always OK..
    If you want to rezie the .ts file you should cut out unwanted sections and demux to a (video) m2v.
    and (audio).ac3 or .mp2. and rezise the video in VirtdubMOD and frameserv it to HC encoder or a faster
    way is to use Avisynth and HC encoder. After encoding remmux the files with ImagoMPEG-Muxer
    if you want a mpg systemfile or a vob file.
    stars....
