I've got some .m2t files using the Apple Firewire SDK from my cable box. The m2t files contain 5.1 sound.
I've tried Streamclip and now ffmpegX, and have yet to be successful in converting the video to another format and preserving the 5.1 track.
Both seem to be able to downconvert to 2-ch mp3.
I've tried selecting audio passthru in ffmpegX, but no luck.
A minor oddity (and possibly un-related/extraneous), I noted that if I select "Play" inside ffmpegx, there is no audio, but if I use mplayer from the command line, there is audio. Obviously ffmpegx can access the audio since it is there to be down-converted, but that's not what I wanted.
Or is there another program I should try (and I'm more than comfortable installing/using any unix utils that might exist).
Thanks,
Mike
I'm not looking to export to DVD video (Video_ts)... I'm looking for any variety of video codec into an avi container, with 5.1 sound.Originally Posted by Frobozz
with a sample 15 minute clip I have, 528x480 video, 5.1 sound, ffmpegX will transcode (with mp3 audio), in 5-10 minutes (1.42 G4 DP).. mpeg streamclip looks to take several hours to transcode
The ts->MPEG is very fast, but all other export options are like molasses
Mike
MPEG Streamclip to join files but not transcode?
By Corbey in forum Video ConversionReplies: 2Last Post: 12th Apr 2013, 13:18 -
ffmpegX 0.0.9x transcode stuck on 99%
By mattr in forum ffmpegX general discussionReplies: 0Last Post: 24th Sep 2008, 05:17 -
ffmpegX 0.0.9 - no sound in the output of a transcode
By mattr in forum ffmpegX general discussionReplies: 2Last Post: 21st Sep 2008, 03:56 -
how to transcode from AC3 to WAV
By phpmysql348 in forum AudioReplies: 3Last Post: 7th Sep 2008, 01:46 -
Help I can't Transcode AC3 to Anything
By Tyrel919 in forum AudioReplies: 10Last Post: 22nd May 2008, 21:01
