I'm not sure if this is the right forum for this, but I recently ripped and burned a copy of Osmosis Jones and when I play it the video and audio are out of sync. I've burned quite a few VCD copies of DVDs and this is the first time that I've encountered this problem. Does anyone have any idea what the problem could be?
some movies r just like that (i.e. 10 things i hate about you and usual suspects)
assuming the audio is outta sync with the video for the exact amount of time throughout the movie, u can use the audio skew feature in the source range filter in tmpgenc to make the audio play earlier/later in milliseconds -
This happened to me once, for instance you run the ripped DVD through DVD2AVI, and the resulting streams are both OK, but WAY out of synch...
It's due to the audio stream not beginning until several seconds into the film. Then, when it's transferred through something like DVD2AVI, it first sees the audio several seconds into it, but pretends it's the beginning.
You need to adjust the audio/video offset, by adding a delay of the exact amount as the desynch. It will probably be an exact amount (like 7, 10 seconds), which translates to exactly 7000ms or 10,000ms. If it isn't an exact second, keep adjusting until it works.
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
Indiana Jones Lego - PS2 version limited in any way?
By lordsmurf in forum Off topicReplies: 10Last Post: 8th Jun 2008, 08:33 -
Indiana Jones and The Kingdom Of The Crystal Skull
By Epicurus8a in forum Off topicReplies: 53Last Post: 2nd Jun 2008, 17:19 -
Indiana Jones 4 title....
By j1d10t in forum Off topicReplies: 4Last Post: 10th Sep 2007, 18:54
