Every time I change the capture resolution higher than 320X480 in V Dub I get that error........ What gives? Aren't you supposed to capture in the same resolution that you are going to be outputing to?
Thanks.
Wraith
Results 1 to 10 of 10
Blow me for faster replies.......
Funny thing, I tried capturing through Videowave 5 and it let's me capture @ 720X480. Or at least it let's me set it to that I'm not sure if it defaults back when I capture. Anyone know why Virtual Dub would do this?
Thanks again.
Apache
Blow me for faster replies....... -
refresh, need help with this anyone?
Well what type of card are you using? ATI?? This is exactly what happened to me using my ATI Rage Fury Pro card. I updated the latest driver for my card, and after, i could cap at any resolution. I used ATI driver# 4.13.7192 Just go to their website to download. If you don't have an ATI card, then i can be of no more help. This worked for me, and i am using windows ME with v-dub. You must have DirectX 8.0 though, to use this driver. You can get that at microsoft.com.
No I am not using an ATI. I understand what you're saying about the drivers, but I have just downloaded the latest drivers for my capture card. I have DirectX 8.0 also. It is not the card because it captures 720 X 480 through Videowave perfect with no dropped frames, just V Dub.
Thanks anyway...
Apache
did you also download and install the direct show 8.x driver from microsoft?
Yeah I have Directx 8.0, I'm on Windows Xp, and I noticed on my other hard drive (Has 98SE) V Dub captures at any res I tell it to. I must not have something right.......
Wraith
Now this is even wierder. I downloaded the VFW driver for Windows 2000 for my Windows XP. I could capture in a bigger format, but not much bigger. Now when I capture it shows my cpu committed 100% and I start dropping frames like crazy. Mind you I didn't drop a single frame before, and my cpu usage was around 50%. Capturing with videowave 5 it stays around 18% with no dropped frames.
The fight goes on.
Wraith
7200 Hard disk, and 500mgz processor with 256 mgs RAM, actually I think it is a driver issue. When I boot to 98SE on my factory 5400 8.5 gig hard drive I have no problems.
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 10:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 12:56 -
convert flv to mp3-error: unsupported video codec (7)-any remedy?
By lilly333 in forum Video ConversionReplies: 4Last Post: 21st Nov 2009, 15:28 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 12th Dec 2008, 00:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 17:51
