Page 2 of 2
FirstFirst 1 2
Results 31 to 59 of 59
    Jan 2006
    The first burner I had came with Roxio which I didn't like at all, and I suggest switching to Nero 6.6 which is only $5 at http://www.pricewatch.com/software_multimedia/265094-1.htm and then downlad latest updates from Nero site. That's what I did 5 or 6 years ago, and have been very pleased ever since. Note it's very important to uninstall Roxio before installing Nero because they are very incompatible.
  2. I dont use Roxio it's junk I use Nero 7
  3. Well, the 129 version seems to be working. When the Pioneer version comes out are you suggesting I flash to that?
    And if you know what you are doing, how do you flash back to an earlier version. Be interested in learning how to do that.
  4. The problem is you will not be able to re flash to an earlier version once you update tp 1.29 it seals off the code to reflash. If it is working then leave it be and just download the new release and flash again with 1.29. I took a chance and upgraded to 1.29 and Sony's are still being turned into coasters just wasted one more today.
    Oct 2006
    Sorry to hijack this thread.
    My 111D was working previously but since upgrade to newer version of ITunes I'm getting 4200 error. Can't burn any purchases or backup iTunes library.
    Help
    Oct 2005
    666th portal
    here's an explanation -
    http://forum.rpc1.org/viewtopic.php?p=192226
    cyrano02 - you might want to try the 111L v8.19 to 8.26 flash before going back. more features and it's a good burning update.
    Oct 2006
    Thanks for the link and the suggestion. Can you give me a dummies guide to what I need to do? By flash do you mean I download an update?
    Jan 2006
    To cross flash to 111L get 111L 8.19 INT and 8.26 INT from http://tdb.rpc1.org/index.htm. Flash first with 8.19 which does actual cross flash to 111L, and 8.26 flashes to latest version.
    Oct 2006
    I'm getting page not found with this link but have went to here http://tdb.rpc1.org/#DVR111D
    I have clicked on 8.19 INT but so far only getting offsite.php in my download software
  10. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    http://tdb.rpc1.org/#DVR111L
    you need to download from the above link.
    Oct 2006
    tried this but still getting offsite.php
  12. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    What browser are you using? I use Mozilla Firefox with no problems in downloading from tdb site.
    Nov 2002
    From the intro on top of the page:
    If you get the offsite page or "phpBB : Critical Error - Could not connect to the database" you have a (http) referer problem, do not email about this.
    Oct 2006
    Using IE6
  15. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Using IE6
    Try using Mozilla Firefox browser to download the files
    Oct 2006
    Thanks will try the flash download once I've got the other browser
    Oct 2006
    Okay 8.19 downloaded perfect with Mozilla. Open the zip and flashed the DVD drive and then restarted system as requested.
    Downloading 8.26 and presented with 2 files in zip. A0412541.826 and R11FOIN.EXE. What do I do next
  18. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    double click on the R11FOIN.EXE and follow the prompts. you could do this in safemode. i flash all my dvd burners in safemode.
    Oct 2006
    I'm getting failed to load binary file. Then update programme terminated. Sorry that I'm asking so many questions
  20. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    did you flash the drive with tdb 111L internal 8.19* firmware first? if you didn't that's the problem, you'll have to flash it with that firmware first before you use tdb 111L internal 8.26. make sure you download the correct tdb 111L 8.19 that has the * .
    flash with tdb 111L internal 8.19* then reboot pc. then flash with tdb 111L internal 8.26 and reboot pc.
    Oct 2006
    Yes, that's what I said in a previous post. Rebooted after 8.19. Then downloaded 8.26
  22. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    make sure you're downloading the correct tdb 8.26, it should be the 111L internal 8.26.
  23. Member
    Oct 2006
    Yes, thanks
  24. Member
    Oct 2006
    Wondering if there is anything else I can do as I'm still not able to use DVD writer
  25. Originally Posted by cyrano02
    I think you have made 2 critical errors here. The first was jumping into an existing thread dealing with cross-flashing a Pioneer 111D to a 111L which has nothing to do with your problem. The second is not providing enough information for people to help you.
    I'm guessing here but..........................
    I assume you are attempting to burn an audio cd out of iTunes and probably are getting an error similar to this:
    "The attempt to burn a disc has failed. An unknown error has occurrred (4200).
    There is info involving this at the DELL Community forums. You'll have to signup before you can search (I think). Search on iTunes and 4200 error. I would suspect your problem is iTunes software. Would suggest uninstall then reinstall iTunes. Remove upper/lower filters. See link here:
    http://support.microsoft.com/?scid=kb%3Ben-us%3B314060&x=12&y=13
    Good luck. If my assumption above is not correct - Please start a new thread detailing your specific issues. Thanks
  26. Member
    Oct 2006
    Okay suitable reprimanded
    Help
    Yes error is 4200 as you have stated, which is what I quoted in original post.
    I'll sign up for DELL forum
  27. Member
    Sep 2005
    [blatant hi-jack]
    Does anyone else with the drive ever have this happen? It starts burning a DL disc at 6.0x from 0 to about 10%. It then drops down to 0x, stays there for a few seconds, then shoots up to 8.0x and continues burning.
    The end product has a slightly darker ring about a quarter of the way from the center of the disk, but disc scans are nearly flawless.
    [/blatant hi-jack]
  28. Sorry - was not intended as a reprimand.
    I'm pretty sure no one picked up on the 4200 error in reference to burning in iTunes. Anyway - hopefully that poster detailing this over at the Dell Forums can help. The screen name of the guy with all the info is called Predator and the link to his site is:
    http://www.the-predator.com/
    Good luck.
  29. Originally Posted by BoilerUp
    [blatant hi-jack]
    [/blatant hi-jack]
    It is normal for the drive to spin down before it changes speed from 6x to 8x. This is often more noticeable on DL media. Should pose no problems.
