got a friend with a Time notebook - G900, and the dvd drive is a Mat[censored]a dvd-ram uj-815a. A software disk won't eject but the software runs ok!!!! Tried the button, tried from My computer, tried from inside programs like Nero, whichever way it sounds like it's trying but just can't do it. Looked through the manual and can't find any manual eject info. With normal desktop drives there's that litle hole that you poke a paperclip in but i can't see anything similar on this drive. The drive is of the type where there is just a slot and the disk slides in.
actually the only thing i could find was this in the manual but it looks like how you remove the whole drive!!!!! No other info in the manual
http://www.geocities.com/jjbtnc/drive.JPG
pop the whole drive out (it slides right out when you pop the release latch)
should be a hole on the bottom or back to release the disk"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Salvaging CPU, RAM and Hard Disk from Laptop
By pchan in forum ComputerReplies: 6Last Post: 24th Nov 2011, 20:06 -
Play AVCHD disk on laptop
By aboveice in forum Authoring (DVD)Replies: 2Last Post: 1st Jul 2009, 04:34 -
Disk Read Error on My Laptop
By The Monkees in forum ComputerReplies: 6Last Post: 25th May 2008, 23:35 -
How to watch downloaded HD movies with no HDMI slot on laptop
By whiteshadow in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 06:04 -
burning error/disk eject
By djspud in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Jul 2007, 15:15
