I had recent posted about a memory proble that is was having,i have new info that i pretty weird.Here is the link to what i posted....https://forum.videohelp.com/viewtopic.php?t=305362.
I just reformated my pc yesterday,i put both ram sticks in my pc,i haveNOT yet put my ati graphics card in,but from the post i stated above,when both sticks and the ati card are in at the same time,thats when i get random restarts,NOT continuious restarts,meaning i only get restarts when i get a powerful program running like a video encoding program or something that takes ram(memory),another ex. is a game.I dont have any problems with my pc like bad drive or cpu going out.Its like the ram is not working right with the card.Any suggestion would be great if we can find a solution for this.Oh btw...my pc can hold up to 2gb of ram.
Here is my specs,i know some of my drivers are out of date,but has i stated above,i just reformated.
P.S.
I have both sticks in without ati card......yes its weird
here it is..
System Information
Time of this report: 9/23/2006, 22:58:06 - ( 10:59 )
Machine name: SHAWN-5OCJVW2AY
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: HP Pavilion 05
System Model: P9851A-ABA 523N
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) XP 2200+, MMX, 3DNow, ~1.8GHz
Memory: 992MB RAM
Page File: 190MB used, 2199MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: S3 Graphics ProSavageDDR
Manufacturer: S3 Graphics Co., Ltd.
Chip type: S3 ProSavage DDR
DAC type: S3 SDAC
Device Key: Enum\PCI\VEN_5333&DEV_8D04&SUBSYS_90221509&REV_00
Display Memory: 32.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: s3gnb.dll
Driver Version: 6.14.0010.0025 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/2/2004 14:02:26, 402048 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: s3gnbm.sys
Mini VDD Date: 3/2/2004 14:02:30, 167040 bytes
Device Identifier: {D7B75DD3-CE44-11CF-A076-28B0A1C2CB35}
Vendor ID: 0x5333
Device ID: 0x8D04
SubSys ID: 0x90221509
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_A ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Vinyl AC'97 Audio (WAVE)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_90221509&REV_40
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: vinyl97.sys
Driver Version: 6.14.0001.4150 (English)
WHQL Logo'd: Yes
Date and Size: 11/25/2005 14:39:06, 203776 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/18/2001 07:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/3/2004 23:07:48, 68224 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:22, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 23:14:38, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 70.8 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800JB-00JJC0
Drive: F:
Free Space: 3.3 GB
Total Space: 19.1 GB
File System: NTFS
Model: WDC WD20 0AA USB Device
Drive: D:
Model: HL-DT-ST CD-RW GCE-8400B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:54, 49536 bytes
Drive: E:
Model: JLMS DVD-ROM LTD-166S
System Devices
Name: S3 Graphics ProSavageDDR
Device ID: PCI\VEN_5333&DEV_8D04&SUBSYS_90221509&REV_00\4&26E 5833C&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\s3gnbm.sys, 6.14.0010.0025 (English), 3/2/2004 14:02:30, 167040 bytes
Driver: C:\WINDOWS\system32\s3gnb.dll, 6.14.0010.0025 (English), 3/2/2004 14:02:26, 402048 bytes
Driver: C:\WINDOWS\system32\nbicdnt.dll, 2.40.0121.0000 (English), 12/19/2003 18:12:38, 761856 bytes
Driver: C:\WINDOWS\help\S3DspWST.hlp, 9/23/2003 02:06:12, 176152 bytes
Driver: C:\WINDOWS\help\S3DspCHS.hlp, 9/23/2003 02:06:04, 18279 bytes
Driver: C:\WINDOWS\help\S3DspCHT.hlp, 9/23/2003 02:06:08, 16534 bytes
Driver: C:\WINDOWS\help\S3DspJPN.hlp, 9/23/2003 02:06:08, 17373 bytes
Driver: C:\WINDOWS\help\S3DspKOR.hlp, 9/23/2003 02:06:08, 18736 bytes
Driver: C:\WINDOWS\system32\S3Disply.dll, 2.00.0007.0922 (English), 9/23/2003 02:07:26, 458752 bytes
Driver: C:\WINDOWS\system32\S3Disply.cfg, 9/23/2003 02:07:38, 62392 bytes
Driver: C:\WINDOWS\system32\S3Displ2.cfg, 9/23/2003 02:07:38, 60904 bytes
Driver: C:\WINDOWS\help\s3in2wst.hlp, 2/10/2004 04:27:02, 39845 bytes
Driver: C:\WINDOWS\help\s3in2chs.hlp, 2/10/2004 04:27:04, 8596 bytes
Driver: C:\WINDOWS\help\s3in2cht.hlp, 2/10/2004 04:27:04, 8645 bytes
Driver: C:\WINDOWS\help\s3in2jpn.hlp, 2/10/2004 04:27:02, 9065 bytes
Driver: C:\WINDOWS\help\s3in2kor.hlp, 2/10/2004 04:27:02, 9067 bytes
Driver: C:\WINDOWS\system32\S3Info2.dll, 2.00.0008.0209 (English), 2/10/2004 04:26:56, 229376 bytes
Driver: C:\WINDOWS\system32\S3Info2.cfg, 2/10/2004 04:27:02, 38191 bytes
Driver: C:\WINDOWS\system32\S3uninst.exe, 1.00.0010.0922 (English), 9/23/2003 01:46:32, 69690 bytes
Driver: C:\WINDOWS\system32\VTPreset.exe, 1.01.0000.0102 (English), 2/24/2004 20:17:18, 45056 bytes
Driver: C:\WINDOWS\help\S3Gm2WST.hlp, 1/20/2004 03:08:38, 129194 bytes
Driver: C:\WINDOWS\help\S3Gm2CHS.hlp, 1/20/2004 03:08:38, 17215 bytes
Driver: C:\WINDOWS\help\S3Gm2CHT.hlp, 1/20/2004 03:08:36, 17492 bytes
Driver: C:\WINDOWS\help\S3Gm2JPN.hlp, 1/20/2004 03:08:36, 16804 bytes
Driver: C:\WINDOWS\help\S3Gm2KOR.hlp, 1/20/2004 03:08:36, 19691 bytes
Driver: C:\WINDOWS\system32\S3Gamma2.dll, 2.00.0009.0119 (English), 1/20/2004 03:09:18, 352256 bytes
Driver: C:\WINDOWS\system32\S3Gamma2.cfg, 1/20/2004 03:09:18, 48879 bytes
Driver: C:\WINDOWS\help\s3ovlwst.hlp, 2/18/2004 03:40:44, 55911 bytes
Driver: C:\WINDOWS\help\s3ovlchs.hlp, 2/18/2004 03:40:48, 9762 bytes
Driver: C:\WINDOWS\help\s3ovlcht.hlp, 2/18/2004 03:40:46, 9732 bytes
Driver: C:\WINDOWS\help\s3ovljpn.hlp, 2/18/2004 03:40:46, 10153 bytes
Driver: C:\WINDOWS\help\s3ovlkor.hlp, 2/18/2004 03:40:46, 10363 bytes
Driver: C:\WINDOWS\system32\S3Ovrlay.dll, 2.00.0010.0217 (English), 2/18/2004 03:41:56, 339968 bytes
Driver: C:\WINDOWS\system32\S3Ovrlay.cfg, 8/6/2003 06:44:38, 54112 bytes
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B091&SUBSYS_00000000&REV_00\3&61A AA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\VIAAGP.SYS, 5.01.2600.2180 (English), 8/3/2004 23:07:44, 42240 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1106&DEV_3147&SUBSYS_00000000&REV_00\3&61A AA01&0&88
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/18/2001 07:00:00, 35840 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1106&DEV_3116&SUBSYS_00000000&REV_00\3&61A AA01&0&00
Driver: n/a
Name: Vinyl AC'97 Codec Combo Driver (WDM)
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_90221509&REV_40\3&61A AA01&0&8D
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:56:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\vinyl97.sys, 6.14.0001.4150 (English), 11/25/2005 14:39:06, 203776 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_90221509&REV_23\3&61A AA01&0&8B
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_90221509&REV_23\3&61A AA01&0&8A
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_90221509&REV_06\3&61A AA01&0&89
Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 8/3/2004 22:59:44, 5376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_90221509&REV_10\3&61A AA01&0&58
Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/3/2004 22:31:34, 20992 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/18/2001 07:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 07:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/18/2001 07:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/18/2001 07:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/18/2001 07:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 00:56:44 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 00:56:46 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:26 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 00:56:46 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.24 27.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
Vinyl AC'97 Audio (WAVE),0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Vinyl AC'97 Audio (WAVE),0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00200000,2,2,,5.03.2600.2180
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
Vinyl AC'97 Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Vinyl AC'97 Audio (WAVE),0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
Vinyl AC'97 Audio (WAVE),0x00200000,12,2,,5.03.2600.2180
I was just reading both of your post. Funny you mentioned this, about 3 weeks back I had the same issue. I have 2 1gig kingston sticks in my pc. One day I kept getting these really screwed restarts. Widnows would display a blue screen for a second then restart. It was NOT a virus. I disabled the restart and wrote down the message. In my case one the memory sticks had gone bad (according to the message I was getting). I too own/use an ati card. It sounds
more like one of your ram chips went bad
To verify this get and download this free app http://www.memtest86.com/
this app will test your memory and you then will know if a stick has gone bad. Mine gave like 22,000 errors upon the initial scan. I stopped the scan and removed one stick and tried it again. I was able to pinpoint which stick was bad. I then switched the stick spots on the motherboard with the good memory stick to make sure it was not from the board itself. All in all one stick went bad. I put in a spare 512 in its place. Right now I am running 1.5 gigs of ram and working ok
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
