I have put 5 avi files through s2d and after say 6 hours it has finished ok and i have watched most of it on the pc.
When i first tried to burn it using Nero a box popped up saying "command sequence error" then "could not perform start of disc at once" followed by "burn process failed".
I then tried to do it in clone dvd but straight away it said " trying to repair defective dvd structure" followed by "please be sure that all input files are available and that they represent a properly master dvd".
Any help would be nice if possible,log as follows.
************************* ProjectMetaData **************************
Processing assets for DVD creation
=================== AV Details ===================
File Size: 349 MB
file=D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 01.avi
FormatName=avi
Num_Frames=36507
DurationInSecs=1460
Duration=00:24:20.2
VideoCodec=mpeg4
Width=608
Height=352
Standard=PAL
BitRate=2010
AudioStreamCount=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
AVI2MPG: 4784kbs Full-D1
11:48:57: Looking for AVI PAR...
Pass 1/1: Processing Return To River Cottage - Episode 01.avi
11:48:58: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
11:48:58: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
11:48:58: libavutil version: 49.0.0
11:48:58: libavcodec version: 51.4.0
11:48:58: libavformat version: 50.2.1
11:48:58: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
11:48:58: Input #0, avi, from 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 01.avi':
11:48:58: Duration: 00:24:20.2, start: 0.000000, bitrate: 2010 kb/s
11:48:58: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 608x352
11:48:58: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
11:48:58: Output #0, dvd, to 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 01_S2D.mpg':
11:48:58: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x576, q=1-31, 4784 kb/s
11:48:58: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
11:48:58: Stream mapping:
11:48:58: Stream #0.0 -> #0.0
11:48:58: Stream #0.1 -> #0.1
12:47:49: video:848751kB audio:39929kB global headers:0kB muxing overhead 2.036345%
12:47:49: AVI2MPG: done.
File Size: 349 MB
file=D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 02.avi
FormatName=avi
Num_Frames=36250
DurationInSecs=1450
Duration=00:24:10.0
VideoCodec=mpeg4
Width=608
Height=352
Standard=PAL
BitRate=2024
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
12:47:49: Looking for AVI PAR...
Pass 1/1: Processing Return To River Cottage - Episode 02.avi
12:47:51: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
12:47:51: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
12:47:51: libavutil version: 49.0.0
12:47:51: libavcodec version: 51.4.0
12:47:51: libavformat version: 50.2.1
12:47:51: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
12:47:51: Input #0, avi, from 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 02.avi':
12:47:51: Duration: 00:24:10.0, start: 0.000000, bitrate: 2024 kb/s
12:47:51: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 608x352
12:47:51: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
12:47:51: Output #0, dvd, to 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 02_S2D.mpg':
12:47:51: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x576, q=1-31, 4784 kb/s
12:47:51: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
12:47:51: Stream mapping:
12:47:51: Stream #0.0 -> #0.0
12:47:51: Stream #0.1 -> #0.1
13:59:36: video:842713kB audio:39649kB global headers:0kB muxing overhead 2.038176%
13:59:36: AVI2MPG: done.
File Size: 349 MB
file=D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 03.avi
FormatName=avi
Num_Frames=36372
DurationInSecs=1454
Duration=00:24:14.8
VideoCodec=mpeg4
Width=608
Height=352
Standard=PAL
BitRate=2017
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
13:59:36: Looking for AVI PAR...
Pass 1/1: Processing Return To River Cottage - Episode 03.avi
13:59:37: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
13:59:37: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
13:59:37: libavutil version: 49.0.0
13:59:37: libavcodec version: 51.4.0
13:59:37: libavformat version: 50.2.1
13:59:37: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
13:59:37: Input #0, avi, from 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 03.avi':
13:59:37: Duration: 00:24:14.8, start: 0.000000, bitrate: 2017 kb/s
13:59:37: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 608x352
13:59:37: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
13:59:37: Output #0, dvd, to 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 03_S2D.mpg':
13:59:37: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x576, q=1-31, 4784 kb/s
13:59:37: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
13:59:37: Stream mapping:
13:59:37: Stream #0.0 -> #0.0
13:59:37: Stream #0.1 -> #0.1
14:20:50: [mpeg2video @ 0068E248]rc buffer underflow
15:11:47: video:845637kB audio:39781kB global headers:0kB muxing overhead 2.036522%
15:11:47: AVI2MPG: done.
File Size: 349 MB
file=D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 04.avi
FormatName=avi
Num_Frames=36075
DurationInSecs=1443
Duration=00:24:03.0
VideoCodec=mpeg4
Width=608
Height=352
Standard=PAL
BitRate=2034
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
15:11:47: Looking for AVI PAR...
Pass 1/1: Processing Return To River Cottage - Episode 04.avi
15:11:49: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
15:11:49: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
15:11:49: libavutil version: 49.0.0
15:11:49: libavcodec version: 51.4.0
15:11:49: libavformat version: 50.2.1
15:11:49: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
15:11:49: Input #0, avi, from 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 04.avi':
15:11:49: Duration: 00:24:03.0, start: 0.000000, bitrate: 2034 kb/s
15:11:49: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 608x352
15:11:49: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
15:11:49: Output #0, dvd, to 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 04_S2D.mpg':
15:11:49: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x576, q=1-31, 4784 kb/s
15:11:49: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
15:11:49: Stream mapping:
15:11:49: Stream #0.0 -> #0.0
15:11:49: Stream #0.1 -> #0.1
16:12:46: AVI2MPG: done.
File Size: 349 MB
file=D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 05.avi
FormatName=avi
Num_Frames=36039
DurationInSecs=1441
Duration=00:24:01.5
VideoCodec=mpeg4
Width=608
Height=352
Standard=PAL
BitRate=2036
AudioStreamCount=1
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
16:12:46: Looking for AVI PAR...
16:12:46: video:839144kB audio:39456kB global headers:0kB muxing overhead 2.043621%
Pass 1/1: Processing Return To River Cottage - Episode 05.avi
16:12:47: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
16:12:47: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
16:12:47: libavutil version: 49.0.0
16:12:47: libavcodec version: 51.4.0
16:12:47: libavformat version: 50.2.1
16:12:47: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
16:12:47: Input #0, avi, from 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 05.avi':
16:12:47: Duration: 00:24:01.5, start: 0.000000, bitrate: 2036 kb/s
16:12:47: Stream #0.0, 25.00 fps(r): Video: mpeg4, yuv420p, 608x352
16:12:47: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
16:12:47: Output #0, dvd, to 'D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 05_S2D.mpg':
16:12:47: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 720x576, q=1-31, 4784 kb/s
16:12:47: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
16:12:47: Stream mapping:
16:12:47: Stream #0.0 -> #0.0
16:12:47: Stream #0.1 -> #0.1
17:10:28: AVI2MPG: done.
17:10:28: video:839188kB audio:39417kB global headers:0kB muxing overhead 2.036514%
17:10:28: Done: Processing assets for DVD creation
Authoring DVD Folders
17:10:29: Creating TitleSet # 1
17:10:30: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
17:10:30: -->: DVDFolders creating VTS
17:10:30: -->: VTS 01
17:10:30:
DVD Folders: Processing D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 01_S2D.mpg...
17:12:08:
DVD Folders: Processing D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 02_S2D.mpg...
17:13:30:
DVD Folders: Processing D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 03_S2D.mpg...
17:14:46:
DVD Folders: Processing D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 04_S2D.mpg...
17:16:01:
DVD Folders: Processing D:\GRABIT DOWNLOADS\RIVER COTTAGE\Return To River Cottage - Episode 05_S2D.mpg...
17:17:15:
17:19:53:
17:19:54: Finalising DVD...
17:19:54: SVCD2DVD: DVDfolders
17:19:54: -->: DVDFolders creating table of contents
17:19:54: scanning D:\SVCD2DVD SOURCE\SVCD2MPG TS FOLDER\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
17:19:54: Finalising DVD...Done
17:19:54: Done: Authoring DVD Folders
Results 1 to 10 of 10
Try the ImgBurn Shell Ext : https://forum.videohelp.com/viewtopic.php?t=308737
and personally i would set SVCD2DVD to use Imgburn as it's burning method going forward as most people agree it is the better option.
All those Nero errors usually indicate bad media BTW...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Ok i have added the shell ext and now it is on my right click.
If i put my mouse over the TS folder it shows 4.29gb but when i right click on it and choose image burn up pops this box.
I have also changed it in s2d to burn with imageburn
Ok lets start again.
Run into more issues so i have removed the shell ext.
When you extract the folder which has been downloaded from the s2d site you have 2 files,setup & imageburn dvd video setup.
Which one is used so it gives me the right click burn option.
This maybe a silly question for people that are now reading it but i have had a few issues and not sure if i was to use one of them or two of them or was there a fault with the ts folder being used ?????
So i thought i would ask which file people have used.
I have already imgburn 2.1.0.0 installed.
Any advice would be nice and hopefully i can just right click and burn in a moment. -
either will do. Try the setup.exe file
With the shell ext, it burns evertything in the parent folder of the VIDEO_TS folder. So whilst your VIDEO_TS maybe 4.29gb i suspect you have other stuff in the parent folder too.... Correct? If so just move things around so you have:
PARENTFOLDER\
PARENTFOLDER\VIDEO_TS
and nothing else.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Ok i have installed the setup exe file.
I now have it on my right click.
OK if you read my post "the one with the picture submitted" this is what now happens.
I have also used different media. -
For anyone who is following this thread,
If you read ALL the posts regarding something someone has pointed you to the answear is there and you then do not need to post pictures and ask dumb questions,or at least it did in my case.
I have now burnt the TS folder in question ok and watching it on the tv.
Apart from that keep up the good work CB -
need advise on a software
By godesdevine in forum Newbie / General discussionsReplies: 4Last Post: 15th Aug 2010, 21:23 -
New PC build - please advise
By Poppa_Meth in forum ComputerReplies: 44Last Post: 24th May 2010, 13:32 -
New to capture, advise?
By ejjames in forum Capturing and VCRReplies: 7Last Post: 30th Aug 2009, 22:36 -
player advise...
By mohit in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Feb 2009, 11:22 -
Advise Required
By dbanga in forum EditingReplies: 6Last Post: 4th Jun 2007, 17:57
