has anyone heard of or does anyone know of any piece of soft that can convert subs (as for instance .srt) to the BETACAM .PAC subtitle format?
so far, pricy Fab Subtitler seems to be the only one dealing with BETACAM .PAC conversion.
EZTitle Convert does the conversion too. we're dealing with a $$$ piece of software again, though...
for those willing to delve into the format, here goes a sample file:
http://rapidshare.de/files/33111370/..._Days.PAC.html
thank you!
Results 1 to 1 of 1
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49 -
Capturing Betacam SP video
By jbigfoot in forum Capturing and VCRReplies: 2Last Post: 15th Mar 2010, 18:47 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
Betacam SP Sizes
By The Sumerian in forum MediaReplies: 2Last Post: 9th Sep 2007, 14:02
