I have a Sony VAIO tower with XP and dvd externals, a Sony DRX-720UL and a Sony DRX-810UL connected via firewire. One is connected to the rear 6-pin connector, the other is connected to the 4-pin in the front. XP is not recognizing either drive, and I'm getting the yellow exclamation marks by them in the device manager. Anybody else have this issue?
Yes but with an add-on firewire card and a Nec drive in a generic external firewire case.
The only way I was able to fix it was to move the card to an alternate PCI slot so windows would recognize it and re-install the drivers again.
On the other hand it could be that the firewire chip is damaged, it could also be caused by a faulty cable.
You may also try removing all
and all related firewire drivers.
I second ofbarea's advice - I too had to move my firewire card to another slot, and once I did I found paradise again.
Good Luck!
TTWC"I've got a present for ya!" - TTWC -
Thanks for the advice. The firewire ports came standard on the pc, never used both at once. The pci firewire cards are inexpensive right now, maybe I will give that a try.
Instead of buying a new card, try connecting only one of the external devices to one of the built-in ports and see if that works.
If it does, then remove that device and plug it into the other firewire port. It it doesn't, then try the other device first on one port, then the other.
Post your results back and we'll go from there.
Thanks!
Ok, did some tests. I have 2 firewire cables, the original OEM one and a one that I purchased through ebay.
Using the 4-pin port in the front of the pc:
810: works with both cables
720: works with the OEM cable only
Using the 6-pin port in the rear of the pc:
720: works with both cables
I now have both writers connected without any issues:
810 : ebay cable/rear 6-pin port
720 : OEM cable/front 4-pin port
I'm a bit confused but everything works.
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 22:34 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 23:44 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 02:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 14:51 -
Buying 2 SATA DVD Writers
By mis3 in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Aug 2007, 23:08
