First time this has happened. When I attempt to drag an avi file into the asset window at the bottom of the screen nothing happens. Simple as that, the file doesn't appear and I cannot get it to load. I have put the files into g-spot and I have all the right codecs and the files play fine in media player so they're not damaged.
I'm running 2.1.2422 and have used many times successfully.
Any ideas anyone ?
What is the audio?
I have had that happen to me in the past. First time it was an avi file with a foreign letter or two in the name. Second time it was a file with two audio streams.
Mark -
Thanks both. It does have dual audio Chrissy but mwkurt has the answer. The filename had the the trademark 'TM' in it and when I renamed the file it was fine.
Cheers.
Blackmagic Intensity Pro - NTSC Captured File Not Recognised at Interlaced?
By kauri in forum Capturing and VCRReplies: 22Last Post: 22nd Nov 2011, 13:21 -
Cedocida DV Codec - 16:9 not recognised?
By BertRito in forum Newbie / General discussionsReplies: 30Last Post: 11th Jul 2010, 21:50 -
Floppy Drive Not Recognised
By spliffy in forum ComputerReplies: 38Last Post: 26th May 2010, 03:45 -
Ipod Not Recognised In Windows Vista
By Teac23 in forum Portable VideoReplies: 2Last Post: 18th Apr 2010, 20:56 -
DVD not recognised in player
By martinbass in forum RestorationReplies: 6Last Post: 6th Oct 2007, 12:32
