From the Westinghouse website @ http://www.westinghousedigital.com/pc-52-2-32-lcd-hdtv.aspx
Progressive Scan, I know what that is
Aspect Ratio Conversion, ?
CCS (Cross Color Suppressor), ?
3D Noise Reduction, Regular Noise reduction I know but 3D?
Inverse 3:2 pulldown, ?, Their website says a technology which correctly reconstructs movie films for display on a digital video device for film at 24fps and digital video displayed 60fps....I understand the pulldown concept for fim to 29.97fps on a regular TV but whay do it to a 60fps disgital?
3D Video Processing, 3D?
3D Comb Filter, Comb Filter I know but 3D Comb Filter?
I'm happy with the picture, Now I just need to wrap my head around some of the concepts such as the way the hd channels are numbered and what it means.
Since the LCD panel is native progressive, it is desirable to convert telecined film source 480i back to 480p/23.976 progressive to improve display quality. This process is called inverse telecine or IVTC.
If 24 fps were displayed directly, it would flicker like crazy. So what is done in HDTV sets and progressive DVD players is a frame repeat to 59.94fps. This is done by repeating alternate frames 2x, then 3x, then 2x and so on. Do the math, that works out to a 23.976 to 59.94 frame rate conversion. Using these techniques all sources (analog NTSC, 480i, 720p and 1080i) are displayed with 59.94 refresh.
http://www.dvdfile.com/news/special_report/production_a_z/3_2_pulldown.htm
In PAL areas, 576i and 1080i are displayed at 50Hz refresh (sometimes doubled to 100Hz).
http://members.aol.com/ajaynejr/vidcomb.htm
http://en.wikipedia.org/wiki/Comb_filter
What do you mean by "the way the hd channels are numbered"? -
I thought that 3D comb filters worked by cleaning up the current frame by using data from surrounding frames. Boy do I feel stupid!
Darryl -
Guilty here too, I though comb filter( As in communication channelisation) was used to get a cleaner TV station signal.
Also, read digital audio folks call comb filters a basic building block in sound effect ?
How many kind of comb filters are out there ? -
Originally Posted by dphirschler
Originally Posted by SingSing
Analog comb filters use delay lines (one to three lines or more) to apply phase cancellation.
Digital comb filters work in 2D (XY analysis for composite to YC) or 3D (XY analysis for composite to YC + motion adaptive mode switching).
Turns out there are several 3D techniques some of which use historical composite picture data, others use motion detection to switch 2D modes based on motion. I shouldn't have said YUV space, it is actually closer to filter mode switching based on XY picture change analysis + frame to frame motion analysis.
Better to read the link. It gets complex. -
Thnaks edDV for the explanations, Your knowledge is encycolpedic when it comes to video.
As to the HD Channels they can have more than one stream in the channel as I understand it? Thus if I tune to a dt channel do they all start with a channel number and then go from there? I hooked up my basic cable feed to the TV and if I tune to channel 721 it shows as 721--2 then that changes to 721 480i stereo etc.
Which also as I understand is really SD signal?
Cheers
Viral marketing-what program is this created in or custom app????
By stealthProd in forum EditingReplies: 4Last Post: 25th Mar 2013, 00:18 -
What do these video terms mean?
By mst in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2011, 15:39 -
High speed hdmi? Is this a marketing gimmick?
By yoda313 in forum DVB / IPTVReplies: 5Last Post: 1st Aug 2009, 21:01 -
Which is better, LCD or Plasma TV in terms of pixelation?
By dzsoul in forum DVB / IPTVReplies: 51Last Post: 12th Jul 2009, 07:14 -
Toshiba says latest round of price reductions part of it's marketing plan.
By ViRaL1 in forum Latest Video NewsReplies: 4Last Post: 16th Jan 2008, 15:30
