What is the easiest way to loop a MOV clip and burn it as a dvd so it plays in DVD players?
Convert it to dvd compliant mpeg then author to dvd with TDA or similar and set 'action to take after each track has played' to 'play next track (loop mode)'
In TDA this setting can be found by clicking on the menu settings button on the menu page ... other apps should also be able to do this eg dvdauthorgui or guifor dvd author etc .... see the tools section (authoring) -
Awesome thanks!
I converted the video just fine to DVD, however when I import it to TDA and view the clip in clip editor it will only play until frame 25 then it will stop. However, manually I can go through the whole clip which is 1802 frames.
Why do i encounter this problem?
Saving DVD Disc Image for someone else to burn complete with autoplay&loop?
By wyclef in forum Authoring (DVD)Replies: 4Last Post: 11th Jun 2010, 00:07 -
GfD lagging while no loop (Jump to the movie directly)
By michcio in forum Authoring (DVD)Replies: 9Last Post: 26th Nov 2008, 02:40 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 20:11 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35 -
5 hour movie on WMP, 90 min movie on MOVAVI
By jchockey in forum DVD RippingReplies: 0Last Post: 24th Aug 2007, 14:14
