Hi,
If I have capped DV on a PC, will it play on a Mac (I don't have a Mac to test...)? And is there a particular codec I should use?
If you've capped as DV AVI, then I believe that it is a universally acknowledged format and will play on a Mac (assuming a suitable DV codec is installed).
I base this on the fact that Macs are used to edit DV AVI - Final Cut Pro being a prime example.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
serious codec issues mac?
By aceswild in forum MacReplies: 10Last Post: 20th Nov 2009, 13:45 -
K-Lite Codec for mac
By pixel zombie in forum MacReplies: 3Last Post: 9th Jun 2009, 03:25 -
How to get avi codec for mac????
By balonglong78 in forum EditingReplies: 14Last Post: 9th Feb 2009, 19:13 -
Cleaning up capped VHS MPEG2 file
By mrwhitethc in forum RestorationReplies: 13Last Post: 13th Feb 2008, 13:05
