My Panasonic DMR-ES40V is going through fatal error (TM) number 6, not finalizing its DVDs.
Before I decide to get it repaired or exchanged (I got a 2-year warranty from Best Buy, and it's still under the Panasonic 1-year warranty) I would like to know, can another DMR-ES40V finalize my stack of unfinished disks? Or is my current DVD Recorder too unique to have its disks read by its ES40V siblings?
Or what if Best Buy no longer carries DMR-ES40V? Would a newer Panasonic DVD-Recorder be able to finalize?
I'm not sure if a newer model would be able to finalize the discs, but the same model should have no problem at all.
I don't know about the Pannies but the Liteon 5001 and 5005 will finalize each other's discs....
I have a Panny E10 & E20 both were interchangeable with finalizing but don't know about E40. I would say yes but not sure...
I discussed finalizing a DVD in another post yesterday, and someone said that after you rip it to disk, you can "finalize" it with FixVTS. This actually fixes problems with DVD images, so they are DVD compliant.
I will try this over the weekend because I have a Philips DVDR985
standalone deck, but it was a POS. For $850 I was able to burn about 30 DVDs. I even had it "fixed" by an extended warrantee, but it never worked properly. So I have a few unfinalized DVD+Rs to fix. If I do try it this weekend, I will try to remember to report back on results.Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
My DMR-ES10 is able to finalize disks recorded in a DMR-E55 and the other way around.
HI,
About 2 years ago I was able to finalize 2 DVD-R that was recorded using one of the Philips recorder but were not been finalized. Since we could not find a copatible DVD recorder to finalse it, so I just tried to do it in my computer and succeeded.
If I remember correctly, I just burned a tiny file to the root directory using Nero with finalize disc option ticked. It is worth a try.
Finalizing a DVD
By calili in forum Newbie / General discussionsReplies: 7Last Post: 29th Mar 2010, 15:40 -
Finalizing a DVD
By gmcsew in forum MacReplies: 24Last Post: 18th Jul 2009, 22:07 -
What happens to the disk when finalizing?
By hurricane1951 in forum Authoring (DVD)Replies: 3Last Post: 19th Sep 2008, 22:54 -
Finalizing
By JaredKnight in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2007, 07:53 -
how to finalizing a dvd+r ...
By jvlbr in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2007, 21:29
