I've got some extra space on a DVD set and would like to stash a few files there for backup, while still being able to play the DVD on my player.
I habitually use Nero to burn, but it doesn't want me to do that.... when making "DVD video" it won't let me select any other files; if I make a "data DVD" and copy the VIDEO_TS folder and some other files, I'm warned it won't be a valid video DVD, and when I go ahead it doesn't play.
I had believed that video DVDs were the same as data, but it apears not.
So how do I add my own files to a video DVD? Obviously this is possible, I have several commercial DVDs with such on them. Doesn't have to use Nero, I'm happy to try anything else that works.
Create a DVD video so that there's the VIDEO_TS and AUDIO_TS folders, and then create a new folder to put the files in. I've done it in Nero and the resultant DVD plays perfectly.Originally Posted by AlanHK
If you're using Nero to author then burn as one process, then try just authoring to get the VIDEO_TS and AUDIO_TS folders, but then create a data DVD dragging those folders over and then create you new folder.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Why does DVD Shrink add RC protection to its files?
By takearushfan in forum Newbie / General discussionsReplies: 5Last Post: 7th Feb 2010, 13:32 -
Video files I add more for a burned disc won't read on my DVD recorder
By Indrek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Jan 2010, 08:30 -
How do I add AC3 'and' AAC to my video files created using meGUI?
By sangood in forum Blu-ray RippingReplies: 11Last Post: 2nd Jan 2009, 16:27 -
Checked stickies, cant add the idx/sub files to a video
By Kaminoshi in forum SubtitleReplies: 8Last Post: 9th Jul 2008, 13:57 -
how to add non-video files to a video dvd
By spiritgumm in forum Authoring (DVD)Replies: 3Last Post: 18th Apr 2008, 22:17
