http://tinyurl.com/l6sww
Jerry JonesEarlier in the year, Korean electronics giant LG indicated it was considering such a product, but now says it doesn't have such a device on its current road map. Other major electronics makers had already decided to pursue single-format players for now, so LG's indicated direction gave hope to some analysts that the format war might be bridged this year.
http://www.jonesgroup.net
Results 1 to 15 of 15
pioneer also said the same thing - then said they were not going to -- and now say they are .... but plextor says the opposite
...of which?Originally Posted by BJ_M
Nothing can stop me now, 'cause I don't care anymore. -
Eventually, all will produce Blueray, HDDVD, DVD+-RW, CD-RW ... if the market is ready to accept the technologies!
Sam Ontario -
..if one of them doesn't die off from lack of acceptance first.Originally Posted by Sam OntarioNothing can stop me now, 'cause I don't care anymore.
¿que?Originally Posted by SingSingNothing can stop me now, 'cause I don't care anymore.
Sony was the 1st betrayed its comrades by including DVD+RW, it unhappened! Consumers love the betrayal - consumers now benefitted with both - and + RW.
Sam Ontario -
The Sony DVD burner that unhappened the DVD+R vs DVD-R format war : DRU700
If you want to get technical, the DRU-500a came first. It did +R and -R as well.
Yes, it was the DRU-500A, the first ever dual format + and - burner to appear on the market. I remember so as the DRU-500A was my first ever burner (and cost me £300 back then).
Correction : The Sony DVD burner that unhappened the DVD+R vs DVD-R format war : DRU500
I still have the DRU-510A. My first DVD burner. Cost me around $280. Boy how times have changed.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Yep and now a bluray or hddvd burner will cost you three times that amount
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Not if you hold out until prices drop significantly, which most people will until theres a unified format or a dual burner for both formats.
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 23:34 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 01:15 -
Panasonic DVD Recorder-VCR Combo unit model "DMR-ES35V"
By Syd Jamal in forum DVD & Blu-ray RecordersReplies: 4Last Post: 17th Jan 2010, 16:27 -
Good definition of "workflow"?
By bryan andrews in forum EditingReplies: 3Last Post: 26th Jan 2009, 08:04 -
Digital Video Essentials High Definition Combo ???
By ofield1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2008, 12:39
