Hi,does anyone know if there are currently any DVD players on the market that will play PAL discs on an NTSC TV,and is also hackable to be region-free?
I have a $50 Magnavox MDV455 at the moment which does both (via the menu options,and hack respectively) and does the job well ,but I want to buy another one that does the same(not neccessarily same model).
I don't think the MDV455 is still available,do you know if any of the current Magnavox models do this,or any other inexpensive players?
Thanks.
Philips DVP-5140 (about $55.00 at Wal-Mart)
Philips DVP-5960 (about $80.00 at a variety of retail stores such as Circuit City)
Oppo Digital DV-970HD ($149.00 direct from http://www.oppodigital.com/)
Oppo Digital OPDV971H ($199.00 direct from http://www.oppodigital.com/)
Of all of these the Oppo Digital OPDV971H will give you the best quality when it comes to PAL to NTSC conversion.
- John "FulciLives" Coleman
P.S.
The Philips models above do not support DTS. The Oppo Digital models however both support DTS. Another option if you want DTS is the Pioneer DV-393-S which does PAL to NTSC and can be made region free but you have to buy it pre-modified to be region free. The cost of that unit is $109.00 making it the cheapest of the bunch that does DTS but is region free and does PAL to NTSC. You can get the region free version at 220-Electronics.com"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Playing PAL DVD on Philips DVP3345V and NTSC TV.
By atarmiga in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2009, 19:31 -
Playing NTSC on PAL DVDRom?
By th3obr0 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Feb 2009, 23:18 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 17:19
