The auto-ripple buttons seems to operate contrary what one would expect. If it's out, then it allows one to post-edit ripple. In prevents post -edit ripples. Doesn't On usually mean depressed?
Probably just semantics, but a title of 'auto-ripple' for a process would tell me that 'ripple' is the default and automatic and if you wanted to switch it off, you would push the button in.
BTW, I hope someone here knows which specific program you are asking about, because more than one uses that term and I don't have a clue.
Ripple effect after using WAX
By SearchQuality in forum EditingReplies: 6Last Post: 31st Mar 2011, 15:57 -
Video has a ripple effect whith any movement?
By David9799 in forum Software PlayingReplies: 4Last Post: 13th Aug 2009, 19:35 -
Vegas:Ripple vs Post-edit Ripple--What's the Difference?
By solarblast in forum EditingReplies: 0Last Post: 25th Sep 2008, 11:21 -
Ripple and Cut/Split
By solarblast in forum EditingReplies: 0Last Post: 24th Sep 2008, 10:32 -
Adobe Premiere Elements 3 - How to auto highlight navigation button
By killme in forum Authoring (DVD)Replies: 0Last Post: 18th Jul 2007, 12:33
