Hi.... I wonder if anyone can help with this odd kind of problem I have with WMP.
Whenever I try to play avi's or mpgs (regardless of codec) it plays the file fine, but I cannot skip ahead or back without it playing the file from the very start..... it also doesn't show the progress on the bar along the bottom as it plays (as if it were not playing).
If I stop play, and then press play again, the same thing happens, if I stop and then play again, it plays it as it should, and the progress bar is useable again to skip ahead or back. So only on the third time I play the file will it allow me to do this.
wmv files play fine and do not have this problem, only with avi and mpg.
Does anyone know what the problem is likely to be?
Thanks very much.![]()
Use a better media player, perhaps? VLC, MediaPlayer Classic.
/Mats -
Thanks.. I have other players, but it's only recently started doing this, I was hoping someone might know why.
It's possible it's to do with codecs since I recently re-installed some.
At the moment I'm getting the DivX icon in the taskbar when I play a file in WMP..... So I'm guessing it's using Divx as the codec, is there a way of choosing another codec as default or something, I never used to get the DivX icon pop up. -
If it happens with files with all different codecs, then it sounds like the player is the problem. If you added some codecs by way of a codec pack, then that may have caused the problem. If you suspect codecs, try Codec Sniper and see if any are corrupted or duplicated. Gspot 2.60 may also tell you if you have more than one codec for the same type of file.
If you are playing a Divx file, you will need a Divx or Xvid codec. -
Originally Posted by MiaBoccamoved to another forum, nobody likes me here...
Windows Media Player: MPG playback bar moves faster than video plays
By Grunberg in forum Newbie / General discussionsReplies: 4Last Post: 15th Sep 2009, 04:07 -
VI format, can they be converted for playback on windows media player
By tiredmom888 in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2008, 09:42 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Windows media player 11 playback codec for DV AVI
By Canadian* in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 27th Mar 2008, 17:56 -
Problem with DVD Playback on Windows Media Player.
By Cereal Bawks in forum Newbie / General discussionsReplies: 5Last Post: 29th Jul 2007, 15:11
