I have just recorded a film from my Leadtek DTV1000 card and went to record the film on to a DVD via Movie Factory 4 that came with the card and all burnt ont othe disk fine with a menu etc, but when I play it the sound is out of sync with what's showing on the screen. If I simply play the movie from the hard disk (mpg fil) where it was recorded it's fine, it's only when i burn it to DVD.
	Welcome to LEADTEK HELL, I have been here since June.
 The problem will happen if you ever try to edit / encode or burn it. The only way I have been able to achieve it is by opening the file in VDM and demux the audio and saving the video as a seperate file. Then convert the audio to CBR mp3 or ac3, then open the new video file and mux the new audio file and set a skew correction value.
 Leadtek should be shot in the head..
 I dont know why but you do have to encode the video out, its not dropped frames, I think it may have something to do with VBR video + VBR audio..
 Hope someone can sort this out for you (and me)
	What a load of rubbish, don't they test these bits of software before taking everyones money.
  Trying to use VirtualVcr with Leadtek Tv2000 expert.By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46
  leadtek PxDVR3200 H - HD component inputBy Thalandor in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 21:10
  Leadtek Winfast pvr2000 (retail)By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05
  What is better than a leadtek expert tv tuner card?By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 14:44
  Leadtek Winfast TV2000 xp deluxe helpBy Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
