Hello !!!
I thought I would give avi.NET a chance ...
I loaded the first VOB file in a "set" of VOBs ... i.e., the main movie.
It processes for sometime saying indexing and it creates a folder with a D2V file and the extracted audio files so it must be using DVD2AVI or DGIndex etc. but ...
After a while I get the following 3 errors in a row:
ERROR #1
ERROR #2
ERROR #3
After that it just sits there looking like this:
SITTING HERE DOING NOTHING
Do I not have something set up correctly? Could it have something to do with the way the DVD was ripped?
- John "FulciLives" Coleman
P.S.
OK all 4 images are now correct!
	Hi,
 do you have MICROSOFT NET Framework installed? If you don't than thats why. Make sure to install newest version which is 3.0 I believe.moved to another forum, nobody likes me here...
	I do have it installed but then again I think it has been awhile now since I installed it so I will update it to the newest version and see what happens then.Originally Posted by fLYtRap
 Thanks for the tip.
  avi.Net Problem: Not producing an .avi fileBy Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 16:22
  AVI.net a confusing problem : using DivX instead of XVIDBy Alterego in forum DVD RippingReplies: 5Last Post: 17th Jun 2009, 13:39
  Problem using Avi.net just started using it.By gargoyle_xlvii in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2009, 14:25
  avi.net to work on vista pc.By Bobtail60 in forum Video ConversionReplies: 2Last Post: 17th Sep 2008, 14:45
  AVI.net sound problemBy Den-2 in forum AudioReplies: 3Last Post: 18th Nov 2007, 12:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
