  1. I’m using Tmpgenc DVD Author 1.6. What I need is to have just a track menu (in TDA wording is a menu used to select a chapter of the clip) without any top menu (useless as I only have one clip). Also I would like to have this track menu as the first action of the DVD.
    Easy to build the track menu that I need, easy to say to TDA that I don’t want the top menu but… how to say that I want the track menu as first action?
  2. The options under Menu Display Settings is probably as close as you get to what you want. This option is under Creat Menu.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    In the Menu Display Settings, select "Only Track Menu", under First Play Action select "Display Main Menu." It will go straight to the only menu that you have enabled - the track menu.
  4. Thanks a lot for your prompt reply, ZippiP. and TBoneit.
    It works ! I thought it was a contraddiction to say "first action: display main menu" AND "enable only the track menu". I was wrong, shame on me!
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You're right, it is a contradiction. TDA is from Tsunami which is a Japanese company, hence the Engrish in their stuff sometimes.
