I have captured a TV clip using hardware MJPEG compression.
I have been trying to cut pieces from the beginning and the ends, but when I save the edited clip, Virtual Dub saves it in uncompressed format (huge file). Is there any way I can save the edited clip to the same format it was captured in (hardware compressed from a Matrox G400.
Sherman
Before saving your AVI output,
Click Video -> compression.
Select your Compression codec, configure and click OK.
Now save your output. -
I discovered this evening that my mistake was probably not selecting direct stream processing for both audio and video. When I did this it worked great.
Sherman
Virtual Dub Conversion Question
By zenzen1 in forum Video ConversionReplies: 14Last Post: 11th Apr 2009, 09:15 -
Virtual Dub 1.8.5 Editing question
By zenzen1 in forum EditingReplies: 3Last Post: 27th Sep 2008, 04:55 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 20:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58
