  1. Alright, i have this divx and want to make a vcd out of it, but i started decoding it to mpg, and ended up with a file of 1.6 Gig, which is a tiny bit too big
    So i was wondering how i could convert it, so that it will fit on one cd....
    Feb 2001
    Berlin, Germany
    VCD has fixed specs, so there is no way. Lower the bitrate to fit it on one CD (XVCD), use a bitrate calculator from the tool section. With lowering the bitrate you will sacrifice the picture quality.
    <font size=-1>[ This Message was edited by: Truman on 2002-01-12 09:56:17 ]</font>
  3. If your player support svcd, try out kingviperssvcd template.
