Uploaded recorded TV programme from Humax. Plays perfectly on desktop with VLC Media player. I want to make a DVD for general use. Found difficulty with Roxio 7.5 DivX-to-DVD (audio out of sync). Took advice from Forum and downloaded DVR Studio Pro to convert .ts broadcast file for burning on DVD ("in one simple step"). No audio! Any suggestions please.
Thanks for response.
HDTV2DVD produces video with 2 second delay on audio.
Convertx2dvd produced no video and no audio. Failed at 00.00.00
Message: # 1 has produced NO data (empty)
#0 has produced NO data (empty) -
If you are getting audio delay or video dropouts, you need to fix your TS files first. Try VideoRedo and it's quickstream fix. You may also try MPEG2Repair.
Problem solved using VideoRedo, whose helpline stated :
You can use VideoReDo either prior to running HDTV2DVD or afterwards. Not familiar with HDTV2DVD and since we are coming out with our own DVD authoring module in the next couple of months, this is a feature that will be part of the VideoReDo family.
Help burning .mt2 files to dvd
By fabes253 in forum Authoring (DVD)Replies: 5Last Post: 7th Aug 2010, 01:30 -
Burning MacRipper Files to DVD
By dea120 in forum MacReplies: 2Last Post: 6th Jun 2010, 11:49 -
Burning to DVD with VTS files
By cameraz in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2009, 21:18 -
burning DVD files
By Itsmeshane in forum DVD RippingReplies: 2Last Post: 21st May 2008, 17:37 -
burning video files to dvd
By brenjim in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2008, 18:41
